emorphien wrote in post #5771072
Even if they did have the same size sensor, with different resolutions, it would still be wrong to refer to them as having the same sensor.
But if the sensors *were* physically the same, I would refer to them as being the same. The resultant image quality would be different, due to the pixel count, but the same sensor is the same sensor.
The higher resolution version could be more than simply cramming more smaller pixels in to the same basic sensor design.
That's exactly what happens, and that was my point originally - that if the sensors are the same, one having a higher megapixel resolution would result in less clarity (rather, more digital noise). EDIT: I misread your post, and missed where you said "could be more than..."
That's still effectively the case - the sensors are *slightly* different in size, and *significantly* different in resolution - i.e. the image quality on the G9 will be less than that of the G7.
