smdevo wrote in post #5773792
"If light is directional it is not soft. If it is soft is is not directional."
Not True. They are not dependent on each other.
A standard grid that goes on a reflector does not affect the source it only affects the spill(or spread). It's the same with a softbox. You still get all the softness of the large light source. The grid just keeps it from flying all around your set.
I have a reasonable idea of the basic mechanics of light, definately not an expert, but not fooled by the concept of a how a grid works either.
Soft light and directional light are in direct opposition. Light with absolute direction would be light from a point source positioned an infinite distance away, light with maximum softness would be light from an infinite number of point sources all very close to the subject.
I also understand exactly how a well designed grid works
The black sides of the light columns absorb light. So only light that is traveling in a straight line, or nearly a straight line, and never touching the black sides ever makes it through the grid. This gives the light a very directional nature. Grids work by removing all the light that does not have a directional aspect.
I think a common perception is that an individual grid cell is like a water nozzle chiding the light to be directional. But this is a poor model. A water nozzle "trains" the water to become directional and all the water entering the nozzle, leaves the nozzle trained.
A grid is more like a sieve. It just removes the light that does not have a highly directional nature. It sifts out what does not conform, no "training" is involved.
The essential function of a grid is to make light directional.
I will stick by this statement:
Grids can control spill, but they will do so at the expense of softness. Again, the light may still be soft enough, but it will be less soft that with the grid removed.
The essence of making light soft is to remove its directional nature (as it is coming from many diffrent sources).
Enjoy! Lon
