Thread started 23 Jun 2008 (Monday) 19:07
Triggering 2 flashes simultaneously
shutter_blitz
Jun 23, 2008 19:07 |  #1
I am trying to trigger 2 flashes simultaneously with one transmitter and 2 receivers (all Cactus V2). But I can only trigger one reciever at a time on seperate channels. Can the 2 receivers fire on the same channel?
SB
Gear:
Canon 50D
EF 50mm f1.4 USM, EF 70-200mm f/2.8 L IS USM
Sunpak 383
Quantaray QSX-9500
FlashZebra
This space available
Jun 23, 2008 19:14 |  #2
If they are identical radio slave sets, just set both receivers to the same so called "channel".
Enjoy! Lon
shutter_blitz
Jun 23, 2008 20:21 |  #3
I bought a brand new cactus V2 set (transmitter and receiver) and a second used receiver.
I tried all the possible channel settings. I can't get the two receivers to trigger simultaneously.
Gear:
Canon 50D
Sunpak 383
Quantaray QSX-9500
PacAce
Joined Feb 2003
Jun 23, 2008 20:28 |  #4
Have you tried moving the receivers far apart from each other? Maybe they're both interfering with each other. Also, make sure the transmitter isn't close to either one of them, either.
...Leo
Bob ­ D.
Jun 23, 2008 21:43 |  #5
shutter_blitz wrote in post #5779040 (external link)
Are they all the same make or do they just 'look' the same. There are a couple different vendors of these so-called eBay triggers, they all may not have compatible channels (or codes if they are using DCS or some other encoding scheme). There are a number of available channels in the 433 MHz band for these low-power devices.
Lotto
Jun 24, 2008 03:02 |  #6
From what I read, the V2 Tx can not trigger V1 Rx. How about use a optical slave on the second flash?
5D, 24-105L, 70-200L IS, 85mm Art, Godox
shutter_blitz
Jun 24, 2008 08:30 |  #7
PacAce,
I will try moving the units apart.
Bob D.
I am pretty sure they are the same brand. I'll check just to be sure.
Lotto,
Which brand do u suggest for an optical slave for a sunpak 383?
Gear:
Canon 50D
Sunpak 383
Quantaray QSX-9500
Lotto
Jun 24, 2008 15:02 |  #8
The Sonia optical slave From FlashZ works fine with my 383.
http://flashzebra.com/​opticalslaves/0003.sht​ml (external link)
shutter_blitz
Jun 24, 2008 17:26 |  #9
Thanks.
Will I lose shutter speed by using an optical slave? I am thinking the delay in the optical slave detecting a flash burst will be a factor.
Gear:
Canon 50D
Sunpak 383
Quantaray QSX-9500
psxindo
Jun 24, 2008 18:01 |  #10
what do you mean by a second used receiver?
could it be that the second receiver is V2 not V2s?
from what I heard V2 and V2s is not compatible.
I used 3 V2 receiver to trigger 3 flashes and it works perfectly.
5D mkIII | 5D mkII | 6D | EOS M | 16-35L | 24-70L | 70-200L 2.8 IS mkII | EF-M 22 | 50 1.4 | 85L | 100 2.8 macro | Tamron 17-50 2.8 | 2x 580 ex II | 580 ex | 2x sunpak 383 | 134GB CF |
Wishlist | 14L | 24L | 35L | 50L | 100L macro | 135L | 15 2.8 FE | 17L 4 TS | 45 2.8 TS | 90 2.8 TS |
shutter_blitz
Jun 24, 2008 18:19 |  #11
Nope, they are both V2s.
Gear:
Canon 50D
Sunpak 383
Quantaray QSX-9500
shutter_blitz
Jun 24, 2008 18:29 |  #12
Ok, so I tried placing the receivers about 5 feet apart. I am not sure if thats far enough, but no dice.
The new receiver triggers on channel 3 and the used one triggers on 4. The first 2 channels don't trigger either receiver.
Gear:
Canon 50D
Sunpak 383
Quantaray QSX-9500
shutter_blitz
Jun 24, 2008 18:39 |  #13
All fixed!
I contacted the seller of the used receiver. The seller had changed the switches inside the receiver to trigger on the 4th channel. Turns out the receiver has the same set of switches as the transmitter, inside. Just need to flip them and I am all set.
Both work great now.
Gear:
Canon 50D
Sunpak 383
Quantaray QSX-9500
1,643 views & 0 likes for this thread
Latest registered member is RileyParker8
943 guests, 242 members online
