Thread started 02 Jan 2005 (Sunday) 09:39
Tungsten and Flash
OceanRider
Joined Dec 2004
Jan 02, 2005 09:39 |  #1
Tungsten and Flash
Does any body have any experience with mixing these two sources in the same portrait?
Canon 20D X 2 & 580EX
Canon EFS 17-85mm f/4-5.6 IS USM
Canon EF 75-300mm f/4-5.6
Canon EF 50mm f/1.8 II
LumiQuest Pro Max; Omnibounce; Newton Di100CR
robertwgross
Joined Nov 2002
Jan 02, 2005 10:51 |  #2
Yes, mostly bad.
---Bob Gross---
Vegas ­ Poboy
Joined Aug 2003
Jan 02, 2005 11:42 as a reply to  @ robertwgross's post |  #3
Just like what Bob said BAD, If you must do a custom white balance.
$$$ in Canon Gear & Lighting Equipment
robertwgross
Joined Nov 2002
Jan 02, 2005 13:43 as a reply to  @ Vegas Poboy's post |  #4
You can let the Tungsten light dominate. Set for Tungsten white balance. Let a little flash fill in if you need.
--or---
You can let the Flash light dominate. Set for Flash white balance. Let a little tungsten light fill in if you need. You might get some yellow edges.
---Bob Gross---
Jon
Joined Jun 2004
Jan 03, 2005 14:08 |  #5
. . . or shove a warming gel over the flash head.
Jon
Cocker Spaniels
1,784 views & 0 likes for this thread, 4 members have posted to it.
Tungsten and Flash
1106 guests, 124 members online
