Thread started 24 Jun 2008 (Tuesday) 06:16
do you DL from the Camera or take out CF and DL from it?
KINGoftheVILLE
Jun 24, 2008 06:16 |  #1
IF I have time I DL with the Camera, change cards when in the middle of a shoot or wedding.
I was at a local cam shop a few days ago and the service guy told a perspective buyer that Nikon was less problems becuase of not having the pins that CF has but CF is better memory. He said if you go with Canon, DL from the camera because putting cards in and out will damage the pins and that is a costly repair.
what do you guys think?
Pete
Jun 24, 2008 06:20 |  #2
Pretty much all of us here will use an external card reader to transfer shots to our computer. Basically because it's a lot faster than connecting via the camera and it's more convenient.
Pin damage inside camera bodies is pretty rare (I've not seen any instances here since I've joined). The CF card slots in camera bodies are very well constructed so by the time the card hits the bottom, the pins are lined up fine - there's no slackage. The only real way for a pin to be bent is if someone sticks something in there that's not a CF card.
Pete
UK SE Catch of the Day
Hermeto
Jun 24, 2008 06:22 |  #3
Putting cards in and out of the camera will damage the pins only if you are extremely careless.
Use CF card reader for download, it’s usually faster than directly from the camera.
dan_1337
Jun 24, 2008 06:45 |  #4
i use a card reader. i don't konw how you can damage the pins if you just put it in and take it out straight.
5D | 24-70L | 28mm f/1.8 | 580EX
John_B
Gallery: 178 photos
Jun 24, 2008 06:51 |  #5
KINGoftheVILLE,
I have been taking my CF cards in and out of my DSLR's for over 6 years now and they all still work, no pins ever damaged on all 3 of my DSLR's or card reader (still have the original one). I have never downloaded pictures from my camera to my computer in all these years. The card readers are quicker and don't waste your cameras battery.
As you can see I wasn't worried about it ;)
click to see (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 24, 2008 08:00 as a reply to  @ John_B's post |  #6
I almost always plug in the camera with the USB cable. The camera connects to the computer automatically, I press the Direct Print button (yes, it can be used, contrary to popular belief) and all the images crawl over to the computer.
If there are many pictures, it takes a while, but there are always other things that can be done then, so I don't see that as a problem.
The only time I use a card reader is if the computer at hand doesn't have EOS Utility installed.
Anders
Colorblinded
Gallery: 18 photos
Jun 24, 2008 08:04 |  #7
1: Remove CF card
2: plug in to Firewire 800 UDMA CF reader
3: enjoy ridiculously fast speeds.
4: put CF card back in camera
5: format
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
strobe ­ monkey
Jun 24, 2008 08:08 |  #8
I always use usb to transfer files from cam to PC. I'm lazy.
While waiting for the files to be transfered, I browse POTN so I don't get bored.
R5, RF 85 f1.2L, RF 50 f1.8, 6D, EF16-35 F4L IS, EF50 f1.4, EF 100 f2.8 L Macro IS
single_track
Jun 24, 2008 08:09 |  #9
emorphien wrote in post #5781657 (external link)
5: format
What is the benefit of formattting each time (or risk of not doing it)? Should I be doing this?
I always want C&C on my shots.
Gear list: 70d, 5d & 40d | 70-200L/f4 IS | 24-70L | 17-40L | Sigmalux | 17-85 IS | Opteka 6.5mm fisheye | 580exII
Flickr: https://www.flickr.com​/photos/120400139@N03/ (external link)
apersson850
Gallery: 35 photos
Jun 24, 2008 08:13 as a reply to  @ single_track's post |  #10
There's no benefit at all. But in some way you have to remove the old images, to free up the space, and formatting is one way to tell the camera that the card should be considered empty.
Delete all images is another.
Anders
Pete
Jun 24, 2008 08:15 |  #11
And formatting is way faster than deleting.
Pete
Colorblinded
Gallery: 18 photos
Jun 24, 2008 08:15 |  #12
There's no point in leaving things on the card IMO, I need the card to store new things as I take them. If I don't format it then it just gets clogged up with older stuff.
apersson850
Gallery: 35 photos
Jun 24, 2008 08:17 as a reply to  @ Colorblinded's post |  #13
Formatting doesn't remove anything but the directory information about where things are stored on the card. Unless you use the "low level" formatting that's available on some models. That actually overwrites what's on the card. But also takes longer time, I presume. I don't have any model with that function.
Anders
single_track
Jun 24, 2008 08:24 as a reply to  @ apersson850's post |  #14
Thanks guys, I am one tiny step closer to knowing everything. I have been using bridge or Windows explorer to erase old images off the CF's.
Vetteography
Jun 24, 2008 08:34 |  #15
Pete wrote in post #5781712 (external link)
When I transfer images from my CF cards to my PC, I use Cut and Paste. The images are gone from the card without any further steps.
I suppose you could copy & paste then go back and delete the images, but why go through the extra steps? It doesn't take any longer to cut than it does to copy.
Of course I could be totally missing the point again....
3,160 views & 0 likes for this thread, 39 members have posted to it.
2982 guests, 130 members online
