Thread started 24 Jun 2008 (Tuesday) 06:18
Learning flash....anything out there for onboard flash?
Jimmer411
Thank god Im green.
Jun 24, 2008 06:18 |  #1
Ive been reading the stickies on flash, as well as the stuff on strobist. The thing is, I cant make heads or tails of any of it because all I have is onboard flash. When I do use my flash its very hit and miss. Ive been playing with manual to try to get more consistent exposure but it seems that if the subject is anymore, or any less than 6-8 feet away my flash is useless... especially for fill.
So how do you guys use your onboard flash? Ive been trying P mode to check how accurate my exposure is compared to the cameras, but still I would like to learn the formula so that I have a better idea of what I need for a given situation rather than taking test shots and hoping for the best.
I would much prefer to master my onboard flash and move up to something better once Ive reached my limits. Ive tried varying ISO, shutter speed and aperature to try to learn this but its no go. Is flash something you can only learn with a flash unit, since I dont have access to guide numbers and such?
Also is there a way that I can use FEC to only adjust the power of my flash? My biggest problem is once I do have the correct exposure, the flash is either too strong or not strong enough but when I adjust FEC it throws everything out of whack.
5D3 | Sigma 30mm f/1.4 HSM | EF 85mm f/1.8 USM | EF 24-70 f/2.8L II | EF 70-200 f/2.8L IS II | 430EX | YN-568EX II | YN-622c | YN-622-TX |
Selling Sigma 30mm 1.4
SkipD
Joined Dec 2002
Jun 24, 2008 06:23 |  #2
In my opinion, the built-in flash is a waste of hardware in my 20D, thus I have never used it and probably never will.
Light from the built-in flash cannot reach across my lenses (large diameter "L" zooms with large hoods) without casting shadows of the lenses (or hoods).
Using the built-in flash for shots of people is a recipe for horrible-looking red-eye.
You cannot aim the built-in flash anywhere but straight ahead (and the stupid "diffusers" for them don't do much at all).
There's not enough light produced by the built-in flash to be useful to me.
Skip Douglas
Derbyshire ­ Weddings
Jun 24, 2008 06:26 |  #3
You really need a separate flah unit to get good results. You have little control over a built in flash. Most high end cameras don't have a built in flash for this reason. If you use an external flash you will soon see the advantages, especially if it's a dedicated unit.
Curtis ­ N
Master Flasher
Jun 24, 2008 06:47 |  #4
Let's talk about what the built-in flash can do, and what it can't.
This girl on her pony was shot with the 580EX but the built-in would have worked just fine. With a guide number of 43 feet, it would have a range of just over 10 feet at f/4 (GN / aperture = distance). I was close enough for that to work here.
IMAGE: http://performancephoto.smugmug.com/photos/317218760_vSkhZ-M.jpg
The shot below is a different story. It was taken at f/10 so the built-in flash would only be good for about 4 feet. I was at least 20 feet away from her. There's no way to use a larger aperture without overexposing the ambient, since the shutter speed can't go beyond 1/250 with flash (or 1/200 depending on the camera).
IMAGE: http://performancephoto.smugmug.com/photos/317220504_RRi9K-M.jpg
For the shot below, I swiveled the 580EX to bounce the flash off the white wall, camera right. It produced a nice soft effect similar to window light, instead of the harsh, face-flattening effect of direct flash. This is something you can't do with the built-in.
IMAGE: http://performancephoto.smugmug.com/photos/317217689_CczAZ-M.jpg
Assuming your lens isn't one of those big honkers that shades the light from the built-in, you can practice with it outdoors and learn how to balance ambient light and flash. Use manual mode on the camera, keep your shutter speed at 1/200 or slower and use the aperture to adjust the ambient exposure. Stay close to your subjects and use FEC to regulate the flash exposure. This skill will serve you well when you graduate to a more capable unit.
AB8ND
Jun 24, 2008 06:47 |  #5
If you are going to use the onboard flash, or advance your photography, you must use Manual, in Program the camera will set itself for an ugly onboard flash picture. In Manual you can use it for fill, shooting at your meter reading or as flash dominate, setting your camera 1 to 1 1/2 steps underexposing than the meter reading. To do this set the shutter speed to something around 1/30 to 1/60 then say you meter this at f/4.0 set the camera to f/5.6 and shoot away, playing with the flash compensation as you wish. With a couple of other hands you could even bounce the onboard off say a white plate, held in front of the flash at some nice angle, about 45 degree works good, into a white (a colored one could add a neat effect) napkin that is stretch out to bounce onto your subject. This bounce would have to be done rather close as there isn't much power in the onboard flashes. The onboard isn't as evil as it is made out to be, I'd much rather use something else, but in a pinch it can be made to work.
Jack
Jimmer411
Thank god Im green.
Jun 24, 2008 16:01 |  #6
AB8ND wrote in post #5781382 (external link)
Jack
I dont shoot in P mode, I only use it while learning flash to see how close my M settings are if Im having exposure problems ;)
Thanks for the advice everyone, I guess that Ill look into an onboard flash :D
1,482 views & 0 likes for this thread, 5 members have posted to it.
1434 guests, 131 members online
