Thread started 24 Jun 2008 (Tuesday) 19:08
Edit Capture Time....Batch?
taygull
Jun 24, 2008 19:08 |  #1
I know I can edit the capture time of a single image in Lightroom but I was hoping someone can give me a solution for doing this to an entire set of images.
For example if the time it was taken was actually 5:41:07 and I wanted it to be 4:41:07 for the first image and then each image make the same change relative to the actual time it was taken.
Any ideas...
FYI...I'm on a Mac, CS3, Lightrom.
www.chrisfritchiestudi​os.com (external link)
McKinney, TX
tim
Light Bringer
Jun 24, 2008 20:00 |  #2
I used a piece of software to change RAW file times once, I forget which, search will find it. Search for something like "change time RAW".
Google told me - Breezebrowser
taygull
Jun 24, 2008 20:14 |  #3
tim wrote in post #5785825 (external link)
I'll check but I don't think Breezebrowser has a Mac version.
McKinney, TX
tim
Light Bringer
Jun 24, 2008 21:14 |  #4
Set your clock back an hour while you do the processing ;)
PixelMagic
Jun 24, 2008 23:32 |  #5
1. Import the images into Lightroom.
2. Select the images that you want to edit the capture time. If the entire folder, use CTRL+A to select all the images).
3. In Library mode, go to Metadata > Edit Capture Time and choose the "Adjust to specific date and time" option.
4. Set the correct date and time for the first image and the others will be adjusted relative to the correction in the first image.
taygull wrote in post #5785572 (external link)
Any ideas...
taygull
Jun 25, 2008 00:25 |  #6
FedkaTheConvict wrote in post #5787000 (external link)
Tried that and it only adjusted the time in the first image?
McKinney, TX
PixelMagic
Jun 25, 2008 00:29 |  #7
When you enter the Edit Capture Time dialog box, does it tell you how many images you have selected?
taygull
Jun 25, 2008 07:55 |  #8
FedkaTheConvict wrote in post #5787245 (external link)
No, The "Edit Capture Time" dialogue box comes up with 3 options,
above the options it states; Modify the capture time stored in this image by entering the correct time adjustment below.
Three options listed here
New Time
Original time xxxxxxxx
Corrected Time xxxxx
This operation cannot be undone Cancel Change
McKinney, TX
PixelMagic
Jun 25, 2008 13:45 |  #9
That's rather odd... I just opened a random folder in Lightroom 1.4.1 and sselected a few non-contiguous images using the CTRL key. When I invoked the Edit Capture Time dialog box I got the message shown in the attached photo. I also tried it with contiguous selections using the SHIFT key with the same result.
How are you selecting your images? Are you using the filmstrip at the bottom of the screen?
taygull
Jun 25, 2008 15:04 |  #10
FedkaTheConvict wrote in post #5790620 (external link)
Yes I'm using the film strip at the bottom, I even tried "select all".
I'm doing this on my Mac, I might try it on my PC and see if it makes a difference. Very strange as I don't get that same option/text you are getting.
McKinney, TX
1,924 views & 0 likes for this thread
Latest registered member is dsk26894
1197 guests, 339 members online
