Why do some cameras start out with ISO 200 instead of 100 ?Like the Nikon D40 for example. Are cameras with ISO of 200-1600 rated the same as 100-1600?
ps249 Senior Member 420 posts Joined Jul 2007 Location: Last seen in Saginaw, Michigan USA More info | Jun 25, 2008 01:16 | #1 Permanent banWhy do some cameras start out with ISO 200 instead of 100 ?Like the Nikon D40 for example. Are cameras with ISO of 200-1600 rated the same as 100-1600? 40D
EatonPhotos Senior Member 996 posts Joined Oct 2007 Location: Kentucky More info | Jun 25, 2008 01:43 | #2 Nikon uses ISO 200, as their base ISO, whereas Canon uses ISO 100 as their standard. ISO 100 & 200 are very similar in what type of image the produce, but it does depend on the sensor & the technology to a point. There are several threads running here on the boards regarding Native ISO's. Use the Search function. It's your friend JamesFacebook Profile
kevin_c Cream of the Crop 5,745 posts Likes: 4 Joined Mar 2005 Location: Devon, England More info | Jun 25, 2008 01:55 | #3 What James just said ^^^ Nikon seem to always start at ISO200, obviously the 'base' ISO of the CCD chips they use, whilst Canon seem to always be ISO 100, although I believe the newer Nikon CMOS chips start at 200 as well, although you can lower it to 100 but I don't think you gain any quality, just longer exposures if needed. -- K e v i n --
Jun 25, 2008 05:40 | #4 ps249 wrote in post #5787434 Why do some cameras start out with ISO 200 instead of 100 ?Like the Nikon D40 for example. Are cameras with ISO of 200-1600 rated the same as 100-1600? ps249, Sony A6400, A6500, Apeman A80, & a bunch of Lenses.............
| Latest registered member is SteveeY 1179 guests, 165 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
