Thread started 25 Jun 2008 (Wednesday) 01:32
Lithium Ion batteries for flashes........
Mark
Dammit I need sleep
Jun 25, 2008 01:32 |  #1
I don't quite understand why it is not possible to buy a Li-ion battery for a flash battery pack like the CP-E4, not even a mod yet.
I was thinking to mod the CP-E4 to connect to
http://www.a123racing.​com/ (external link)
these batteries
would this have better recycle speed than NiMH in the CP-E4, or maybe even a Quantum turbo?
Mark
unferth
Jun 25, 2008 11:26 |  #2
That should work, I think most of the typical lithium ion batteries are 3.6 volt cells so that'd get you 7.2 volts which might be too much.. but these are 6.6... innerestin.....
...I've been thinking about building an external battery pack using sub-c nimh batteries... I'm going to use 5 so I get 6 volts instead of 4.8 from using the 4 inernal AA's so that extra voltage should help with the recycle times...
www.trolards.com (external link)
tim
Light Bringer
Jun 25, 2008 19:07 |  #3
Check out this thread, it's somewhat related.
Mark
Dammit I need sleep
Jun 25, 2008 22:46 |  #4
The main thing I was wondering about is if it would be better than the lead acid or NiMH chemistries
Mark
QX56
Jun 25, 2008 23:19 |  #5
pendulum15 wrote in post #5793627 (external link)
If you can get voltage between 8-9 volt ....yes it will work . But if you look at the amp rating ,you need around 3-3.5 amp draw to operating the system longer period .
The importance is voltage 8-9 and then amp 3-3.5 amp .I found some SLA about 8 Volt and 3.2 amp to work with CP-E4 .
Main thing I want is :
-Low cost ( SLA is the cheapest in the market)
-Reliable (most of SLA is last longer than Nimh or Lithium)
1D MK III,40D,G12.1Ds mk3.
24-70L,100-400L ,70-200F2.8LIS,85L,180L macro.18-200EF-S.8-15mmL.
Raynox DCR250,Kenko set extesion tube,ST-E2.
28-200,75-300,KenKo 2X TC,430EX,580EX II,Metz45 CL1.
Mark
Dammit I need sleep
Jun 26, 2008 00:13 |  #6
QX56 wrote in post #5793767 (external link)
how about 4.6Ah and max draw of about 138A
Mark
tim
Light Bringer
Jun 26, 2008 03:34 |  #7
ah is amp hours, it's a measure of capacity, and it's not important in calculations except to say how long it'll last between charges. All SLA bats will give you more current than you can use. Just make sure to get the voltage right.
QX56
Jun 26, 2008 05:16 |  #8
pendulum15 wrote in post #5793965 (external link)
My friend he didn't test that high amp 4.6amp yet so I can't tell you about that , what he told me is : 8-9 volt and 3-4 amp max.
For what I understand is Li (lithium) is better than Ni (nicad) and more expensive too,but it give better:
-Amp
-Stay cooler than Ni when the current draw
-less weight
In the future I will try both Lithium and SLA and see which one last longer and more reliable .
1,114 views & 0 likes for this thread, 4 members have posted to it.
2797 guests, 167 members online
