Thread started 25 Jun 2008 (Wednesday) 12:11
How many stops will I gain going from 650 to 1000ws?
M ­ Powered
Jun 25, 2008 12:11 |  #1
Anyone know?
Canon 5D Mark III | EF 24-70 f/ 2.8 L II
http://www.keslertran.​com (external link)
http://keslertran.tumb​lr.com (external link)
unferth
Jun 25, 2008 12:22 |  #2
every time you double the power you gain a stop so theoretically almost 1 :)
but that depends on the efficiency of the strobes and if they're producing that much light or just using that much power...
www.trolards.com (external link)
M ­ Powered
Jun 25, 2008 12:29 |  #3
unferth wrote in post #5790166 (external link)
So basically from F11 I can shoot at F16 so + another 350ws I can shoot say... F20?
Curtis ­ N
Master Flasher
Jun 25, 2008 12:36 |  #4
M Powered wrote in post #5790207 (external link)
No.
You need to double the power (theoretically) for each additional stop.
So if you can shoot at f/11 with 650ws, you would need 1300ws to shoot at f/16, 2600ws to shoot at f/22, 5200ws to shoot at f/32, etc.
This assumes all other factors are equal, including efficiency of the strobes, same modifiers, same distance, etc.
unferth
Jun 25, 2008 12:43 |  #5
All else being equal, going from 650 to 1000 ws should get you from F11 to F14 (2/3rd stop) but to go from f11 -> f20 you'd need 1 2/3rd more stops from f11 so..
650 * 2= 1300 (one stop)
1300 * 1.6 = 2200 (or so).. so you'd need a whole pile of power :)
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Jun 25, 2008 12:50 |  #6
Can someone enlighten me as to why one would need/want to shoot a model at f/16 or f/22? How much DoF does one need anyway? I can understand that if shooting portraits, it is sometimes desirable to shoot with a shallow DoF.
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
Curtis ­ N
Master Flasher
Jun 25, 2008 12:58 |  #7
ebann wrote in post #5790329 (external link)
In order to properly expose a sunny background at X-sync speed (1/250), you'll need to be around f/10 at ISO 100. If you wanted to underexpose the background (for artistic reasons), you will need to stop down from there.
M ­ Powered
Jun 25, 2008 13:09 |  #8
To overpower the Sun. Slap on small/ medium diffuser and you'll end up not having enough power.
goto www.rrpix.com (external link) and look at his beach collection. Want to guess how much juice you need for something like that? My guess would be 2500ws ;)
ebann
Joined Jan 2003
Jun 25, 2008 13:15 |  #9
Curtis N wrote in post #5790359 (external link)
I was going to ask "Why would one need more light on a sunny day?" when I read the next post...
M Powered wrote in post #5790437 (external link)
That is an interesting and non-obvious concept! More light needed on a sunny day! Unless it's the old fill-in flash we're talking about?
Is it right to conclude that a studio would require far less power since there is no sun to overpower?
Ellery Bann
Fuji X100
M ­ Powered
Jun 25, 2008 13:18 |  #10
ebann wrote in post #5790479 (external link)
Yea, its very ironic, need more light for a sunny day :)
Meter the sky and shoot the model on a bright day, the model will be almost completely dark. Now take that and drop the sky by 2-3 stops... now figure out how much juice you will need to light the model :) Depending on your lens, you might need to slap on a 2 stop ND filter.
Your average size studio you will probably wouldn't need anything more than 300ws.
Galaxy99
Jun 25, 2008 14:00 |  #11
a side question, how much power does a EX580 II give you?
ebann
Joined Jan 2003
Jun 25, 2008 14:08 |  #12
Galaxy99 wrote in post #5790688 (external link)
From photo.net:
"Matt K (external link) , Dec 19, 2005; 04:31 p.m. As mentioned, it will depend on the zoom setting. Also, watt/seconds is not the most accurate/consistent way to judge power output.
That said, I have a 580EX and a Lumedyne kit. I've compared the two directly under the same conditions...
With 580EX set to full manual at 35mm zoom setting and no modifiers, I get a reading of about f/8, ISO 100 at about 10 feet.
With a Lumedyne 067 400WS pack with one head with just a reflector in the normal position, I get a reading of about f/16, ISO 100 at 10'
So given that, the 580EX is about 2 stops lower than my 067 Lumedyne, or "roughly" 100WS. Not bad for a shoe-mount flash. But adding any modifiers and/or widening the zoom coverage and it can become limiting depending on what your subject is."
Wouldn't make a dent in overpowering the sun...
Ellery Bann
Fuji X100
unferth
Jun 25, 2008 14:13 |  #13
http://photo.net …a-fetch-msg?msg_id=00EZNc (external link)
so... about 100ws or so for a 58 gn size flash.. (580ex, Metz 58's , etc.)
Curtis ­ N
Master Flasher
Jun 25, 2008 14:18 |  #14
My estimate is lower than those above. compared to an Alienbees B1600 and fired into the same umbrella, I calculate about 40 ws.
M ­ Powered
Jun 25, 2008 14:47 |  #15
Curtis N wrote in post #5790792 (external link)
Thats it??? just a measly 40ws?
1,679 views & 0 likes for this thread, 5 members have posted to it.
2843 guests, 161 members online
