Just wondering about my BGE2N, When i have 2 batteries in it it wil eventualy show 1 bar of battery left, when i go to charge it one is empty and the other is full, Why wont it run both down and how do i fix this?
ANGUS Cream of the Crop 6,897 posts Joined Apr 2007 Location: Sydney, Australia... More info | Jun 26, 2008 01:14 | #1 Just wondering about my BGE2N, When i have 2 batteries in it it wil eventualy show 1 bar of battery left, when i go to charge it one is empty and the other is full, Why wont it run both down and how do i fix this? Angus
Michael Cream of the Crop 5,981 posts Likes: 3 Joined May 2006 Location: Perth, Western Australia More info | Jun 26, 2008 02:37 | #2 NSWESP wrote in post #5794205 Just wondering about my BGE2N, When i have 2 batteries in it it wil eventualy show 1 bar of battery left, when i go to charge it one is empty and the other is full, Why wont it run both down and how do i fix this? No idea, but call Canon- if it is broken they should warranty it. Michael
ANGUS THREAD STARTER Cream of the Crop 6,897 posts Joined Apr 2007 Location: Sydney, Australia... More info | Jun 26, 2008 02:41 | #3 Sinkrate wrote in post #5794455 No idea, but call Canon- if it is broken they should warranty it. Not sure if it is broken, Will wait till monday if there is no conclusive answer off to canon it goes. Angus
menehune Member 121 posts Joined Jun 2005 Location: Honolulu More info | Both are supposed to discharge at the same rate. You may have to check to see if your batteries are making good electrical contact with the BG-E2N. Try inserting only one battery in the grip and alternate it between the two battery bays. If your camera doesn't power up, that particular bay's contacts may need to be cleaned or are broken.
ANGUS THREAD STARTER Cream of the Crop 6,897 posts Joined Apr 2007 Location: Sydney, Australia... More info | Jun 26, 2008 03:06 | #5 menehune wrote in post #5794495 Both are supposed to discharge at the same rate. You may have to check to see if your batteries are making good electrical contact with the BG-E2N. Try inserting only one battery in the grip and alternate it between the two battery bays. If your camera doesn't power up, that particular bay's contacts may need to be cleaned or are broken. I just tried that and if i put a battery only in the section closest to the shutter button it wont power up, if i put the same battery in the other side it will, but i have no idea if i can place only one battery in that section? Angus
ZGMF-X20A I didn't say anything 1,252 posts Joined Mar 2008 Location: Socal - LA/OC More info | Jun 26, 2008 03:21 | #6 Seems like the other one is not connected, that's why it's not discharging. Jonathan Sutantio
menehune Member 121 posts Joined Jun 2005 Location: Honolulu More info | One battery will work in either bay. I just checked mine to confirm this. See if the contacts in the right battery bay look like the ones on the left. They may just need a little cleaning with an eraser or may be bent upwards a bit. There is also a plunger switch above each battery. My guess is that they are there to check for the presence of batteries. Check to see if the plunger thingy plunges or is broken off.
| Latest registered member was a spammer, and banned as such! 2833 guests, 160 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
