Thread started 26 Jun 2008 (Thursday) 12:40
Simple CS to CS3 question
Halliday
Jun 26, 2008 12:40 |  #1
I just upgraded from XP to an iMac. Along for the ride I went from CS to CS3. CS had a setting that opened the images full screen, stacked on top of each other.
How do I do that in CS3? Not tiled, all full but one behind another with the closing dot up in the corner too?
Thanks. I'm sure it's simple but can't see it. It's affecting my workflow :|
Edit: And have the images centered too on the screen would be great!
lanceshuey.com (external link)
"Like a mechanic who forgets to wipe his hands on a shop rag and then goes home, hugs his wife, and gets a grease stain on her favorite sweater — love touches you, and marks you forever."
PixelMagic
Jun 26, 2008 12:50 |  #2
I can't say I ever noticed that feature in CS and I used it extensively but that's not how I work so its possible I never saw it.
Photoshop CS3 introduced a new screen mode; in previous Photoshop version there were three; Standard (windowed), Full Screen with Menu Bar, and Full Screen. In CS3 there's a fourth screen mode called Maximized Mode which opens your photo without the annoying window around it. The cool thing about it is that it is sticky...if you select it and close Photoshop it will remember the screen mode when you reopen it. You can cycle through the screen modes by pressing the F key or clicking the little downward pointing arrow on the last icon of the tool bar.
Is that what you're looking for? Alternatively you can open several images and then go to Window > Arrange and select how you want them stacked.
Halliday wrote in post #5796992 (external link)
Halliday
Jun 26, 2008 13:11 |  #3
Using F helped a lot. Thou now on the second or third setting there is no 'close' dot at the top left. Any idea how to shot that too?
Edit: The top menu bar is blocking the close dot.
René ­ Damkot
Jun 26, 2008 13:12 |  #4
Do you mean like th screenshot below?
That is the default on my Mac with CS2.
CS3 is the same in the "standard" screen mode.
Press F a few times to cycle through the viewing modes.
One difference between CS/CS2 and CS3 is, that the screen mode you set now affects *all* images that are open, not just the front one.
IMAGE: http://img.skitch.com/20080626-nwm5aq9uj7rk7qs9wg7jnhg262.jpg
edit: The "close" dot is only there in the first screenmode IIRC.
You don't need it: press Cmd+W to close the front window.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Halliday
Jun 26, 2008 14:59 |  #5
Referring to the image above, I'd like to set it up that each image is full, stacked (not showing the images below) and with the close dot showing. I use a tablet so with the stylus in my hand it's easier to hit the close dot than use a keyboard command.
So with the screen shot, put the windows on top of each other and show the close dot.
René ­ Damkot
Jun 26, 2008 16:21 |  #6
Not possible on OSX. That's the windows version of PS :p
From this starting position (my screenshot), press F once. IIRC that takes you to the "new" screenmode of PSCS3. That's as close as you're going to get on OSX.
Are you seriously suggesting you are using a tablet and no keyboard shortcuts :eek:
Halliday
Jun 27, 2008 20:24 |  #7
I have to use a few keyboard commands now with a mac. I sometimes get on the interweb using my tablet :)
PixelMagic
Jun 27, 2008 22:12 |  #8
The solution would be to reprogram your pen. I have the front rocker switch set to "Pop Up Menu" and I've put a list of the keystroke commands I use most frequently listed in the pop up menu. You could easily put CTRL+W, the Close command, there.
Halliday
Jun 27, 2008 22:35 |  #9
Not a bad idea reprogramming. The only thing I've customized was turning off my non-dominate hand side touch strip.
Tonight I'm using the keyboard for the closing. It's working so far :)
Robf
Jun 28, 2008 10:24 |  #10
René Damkot wrote in post #5797198 (external link)
yes, and its a big pain in the neck ! :evil: especially with the extra hoop jump of the extra usless screen mode added as well.
René ­ Damkot
Jun 29, 2008 08:07 |  #11
Then again, you can press shift+F to toggle back a display mode...
But the CS2 way has some advantages, I agree.
Nouks
Jun 29, 2008 16:13 |  #12
René Damkot wrote in post #5798314 (external link)
I'm sorry, but I think it actually is possible. Somewhere under "view". The one you posted is "standard view", one of the others will be a bit Windows-like.
I used to be Gebruikersnaam.
Gearlist: 1D2, resurrected 20D, 400D, 16-35L, 28-70L, 70-200L, 85 F1.8, cute 18-55, dead 24-70 Siggie, 2 flashlights, expensive bags and loads of CF-cards.
Website (external link)Portfolio (external link)Archive (external link)
1,313 views & 0 likes for this thread
Latest registered member is Dharmadme
941 guests, 254 members online
