While trying out the RRS L-plate several things occurred to me.
1) While the L-plate does not block the ports on the side (USB, Shutter Remote, etc.), it does make it rather hard to open with my fingers. I've resorted to using a card to open it now, but perhaps there's a better way.
2) Another concern is if I use the L-plate in portrait orientation. Doesn't that pretty much block all the ports (haven't actually tried yet)? That would make the wired shutter remote useless, but I think you also need to use the wired remote to do mirror lock-up.
3) With the L-plate attached, the camera seems even more unstable than before when not using a tripod and I'm merely resting it on a surface. i.e., the camera immediately tilts forward, resting on its lens. Maybe attaching the flash will improve its center of gravity though... this is mainly for times when I cannot use a tripod but am trying to improvise by resting the camera on something. It would sorta defeat the purpose of having a plate if I'd have to unscrew the plate on and off for these situations.
