Thread started 26 Jun 2008 (Thursday) 14:43
Hoya Pro filter with a smear ?
Amamba
Jun 26, 2008 14:43 |  #1
I just got my Hoya Pro CPL filter from hvstar and there appears to be a smear of some sort smack in the center of the filter - on the INSIDE of the upper (rotating) part !!!
Is there any way to clean it ? i.e. any way to take it apart to clean & put it back together ?
If not, has anybody ever returned anything to hvstar ?
I don't know if this smear has any effect on sharpness / iq, but I didn't pay to have it, and it would make re-selling this filter hard.
Ex-Canon shooter. Now Sony Nex.
Life Lessons: KISS. RTFM. Don't sweat the small stuff.
My Gear List (external link)
Double ­ Negative
*sniffles*
Jun 26, 2008 16:31 |  #2
Crap caught in between the two glass plates is next to impossible to remove; the only way is to disassemble the filter. If you're lucky there are slots on the retaining ring that you can get a screwdriver into, though this is fraught with peril... One slip and you've just gouged your CPL.
Probably better off returning it. :(
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
sgogula
Jun 26, 2008 17:04 as a reply to  @ Double Negative's post |  #3
Same problem here, I received Hoya Pro 1 CPL from hvstar a couple of days ago and do not know how to return it as they are based out of Hong Kong.
I tried to clean it with cleaning liquid, lens pen but it didn't go away.
Canon 5D III | Canon 24-70 L II | Canon 50D | Canon 70-200 2.8 L IS II | Sigma 17-50 OS | Canon 50mm f1.8 II | 580,430 EX II Speedlite
jhom
Jun 26, 2008 17:22 |  #4
I would suggest emailing hvstar with your problem. Ask for instructions for returning the filters. About a year ago, I got a B+W CPL from hvstar with a defect in the foil. I contacted them and returned it. They replaced it with a new one without problems.
Jim
Haru
Jun 26, 2008 18:13 |  #5
Got mine last night and it was smeared as well. But mine came off with some cleaning solution. Email them and ask them how to return is the best advise I've got. The filter came with about 50 stamps stuck on it so I guess it could go back the same way. =P
Gear: Stone slab, hammer, chiseL, and crushed barries.
sgogula
Jun 26, 2008 21:27 as a reply to  @ Haru's post |  #6
I just sent them an email to check if they could replace the filter.
Double ­ Negative
*sniffles*
Jun 26, 2008 22:22 |  #7
This can happen with any vendor, but you really have to wonder if it's worth going back-and-forth with a source in Hong Kong...
jhom
Jun 26, 2008 22:56 |  #8
Double Negative wrote in post #5800232 (external link)
Except for lost time, there really isn't much of a difference than dealing with a domestic retailer. In my experience, I packed up the filter and mailed it via USPS to HK. In turn, I received a new replacement via USPS.
If you are not in a rush, then the saved money is worth the possible hassle if it should occur.
Jim
sgogula
Jun 27, 2008 05:58 |  #9
jhom wrote in post #5800447 (external link)
How much did you pay for the postage?
jhom
Jun 27, 2008 07:33 |  #10
I believe $7 or 8.
Jim
Double ­ Negative
*sniffles*
Jun 27, 2008 08:33 |  #11
^ As long as the savings are there, I guess it's just the slow postage back/forth...
jhom
Jun 27, 2008 09:35 |  #12
With hvstar, the savings are worth any minor inconvenience in regards to time. It is always helpful to plan ahead. When it comes to filters, most effects can be duplicated in photoshop. Besides, I'm from the no filter unless necessary school of thought. So, quick delivery is not a problem.
Jim
bagtagsell
Jun 27, 2008 10:04 |  #13
2filters.com is a domestic place to get a deal on filters.
Mark Ryan Photography (external link)
CoolToolGuy
Boosting Ruler Sales
Joined Aug 2003
Jun 27, 2008 20:52 as a reply to  @ bagtagsell's post |  #14
Hoya filters are notoriously tough to clean. Even if you send the filter back, some day you will get a smudge on the new one and you will likely run across the problem then. Regular lens cleaning fluid will not cut it.
There is a cleaner known as ROR - Residual Oil Remover - that works really well on Hoya filters. B&H sells it, I'm sure other places have it as well.
http://www.bhphotovide​o.com …esidual_Oil_Rem​over_.html (external link)
Have Fun,
Rick
My Gear list
jhom
Jun 27, 2008 21:05 |  #15
CoolToolGuy wrote in post #5806366 (external link)
Have Fun,
I've found that denatured alcohol works great cleaning filters and lenses. It is inexpensive and readily available at Home Depot or any hardware store.
Jim
1,840 views & 0 likes for this thread, 7 members have posted to it.
2717 guests, 158 members online
