Thread started 26 Jun 2008 (Thursday) 18:00
converter?
Cheekaa
Jun 26, 2008 18:00 |  #1
Can someone tell me what is a converter and when do I use it.;)
Saludos!
Jamie ­ Holladay
Joined Nov 2005
Jun 26, 2008 18:02 |  #2
In easy terms a converter extends the range of your lens. Take a 1.4 x TC, it will take a 300mm to 420mm (300*1.4=420). It mounts to the camera body and then the lens mounts to it.
eddarr
There's Moderators under there....
Jun 26, 2008 18:53 |  #3
It also reduces the amount of light hitting the sensor. 1 stop for the 1.4 and 2 stops for the 2.0.
Hopefully your talking about a TC rather than a raw converter.
Eric
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jun 27, 2008 08:55 |  #4
True. Then it would be helpful if you said what you need the lens to shoot? Remember, It also reduces the amount of light hitting the sensor + you will get a noticeable drop in quality with some lenses.
70-200 f/2.8 & 2X TC combination "Test"
Cheekaa
Jun 27, 2008 15:04 as a reply to  @ eddarr's post |  #5
eddarr thank you for the info, but I am new at this, so... I don't even know what is the difference betwen the two of them.
Thanks again cheekaa:(
Saludos!
eddarr
Jun 27, 2008 15:48 |  #6
Just the amount of magnification and the loss of light. The 1.4 will increase magnification by 40% and one stop of light. The 2.0 will increase magnification by 100% and two stops of light.
Assuming that you will be able to get good shutter speeds the loss in light may not be a big issue.
Eric
Cheekaa
Nov 18, 2009 16:35 |  #7
Cheers!!!
thank you!
Jamie Holladay wrote in post #5798872 (external link)
Saludos!
965 views & 0 likes for this thread, 4 members have posted to it.
converter?
1129 guests, 149 members online
