Thread started 03 Jan 2005 (Monday) 13:56
How many of you use a polarizer regularly?
PaulDB
Joined Oct 2004
Jan 03, 2005 13:56 |  #1
Hi all,
Im still pretty new to this but I've just been doing some reading up on polarizers and I was wondering how many of you actaully use them and what your oppinions are?
Is it something everyone should own?
Canon EOS 30D
100mm F2.8 Macro | 17-40 F4L | 100-400 F4-5.6L IS| 18-55 Kit | 580ex
Work in Progress: http://www.photos.bick​erd.com (external link)
Jon
Joined Jun 2004
Jan 03, 2005 14:27 |  #2
Yes. I don't use mine as much as I should - gotta re-arrange the old camera bag so they're easier to get to.
Jon
Cocker Spaniels
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Jan 03, 2005 14:30 |  #3
If you shoot landscapes and other such natural shots, or building or cars where glass can cause reflections, then Yes, you should own a polarizer.
If you shoot a lot of action, or wildlife, or indoors, or flash then you will probably never use it.
Do you have a need or desire to reduce glare or reflections? Can you live with a 2-stop reduction in shutter speed? If the answer is Yes to both then again, Yes, you should own a polarizer.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
PaulDB
Joined Oct 2004
Jan 03, 2005 15:16 as a reply to  @ Scottes's post |  #4
I do wildlife and nature shots mostly at the moment so I think I will get one. Thanks for the advice!
Canon EOS 30D
Bodryn
Joined Jul 2004
Jan 03, 2005 16:56 |  #5
They can also be useful for wildlife shots where water reflection is an issue: you can practically eliminate water surface reflection when shooting at about a 45 degree angle into the water. For example, your subject may be on top of the water and a polarizer gives you choices about the brightness of the surrounding water. If your subject is under the water, it may make the difference between a clear image of the subject and no image at all. I routinely keep a polarizer on my camcorder and 35mm cameras and I would on my digicams if they allowed it. Also, when your subject is at about at a 90 degree angle from the sun, the sky brightness can be nicely controlled. You may like the sky bright or you may like it dark: the polarizer gives you a choice there, too. I love it for what it can do to bring out clouds that otherwise would look hazy.
Bodryn ========
Canon A540; A720 IS; S5 IS; SX20 IS; Pentax *istDS + lots of lenses; Jasc PSP v.9;
"Where are we going? And why are we in this handbasket?
robertwgross
Joined Nov 2002
Jan 03, 2005 18:14 as a reply to  @ Bodryn's post |  #6
In the summer season when the sky is nice for landscapes, the circular polarizer resides almost permanently on my workhorse lens. I take it off for dim light, do the shot, and then put it right back on.
However, when you are jammed for speed, you will want to get those two stops back, so the polarizer comes off.
---Bob Gross---
FlyingPete
I am immune
Joined Oct 2003
Jan 04, 2005 00:39 as a reply to  @ robertwgross's post |  #7
Used mine heaps on my G3 (with adaptor), have used it a bit on my 20D in the last week, however I'm not that impressed with the results as they all appeared over exposed, this could be due to dark skies and dark foliage though.
On my G3 I always set AE lock before positioning the filter into the correct orientation, perhaps I need to do the same on the SLR?
One nice thing though would be an autopositioning CPL :lol:
Peter Lowden.
EOS R6 and assorted glass
robertwgross
Joined Nov 2002
Jan 04, 2005 00:56 as a reply to  @ FlyingPete's post |  #8
When I first started using a circular polarizer, I routinely twisted it around to the maximum effect. Much later on, some friends viewing the prints said,"that doesn't look real" or something like that. After that, I noticed that I can get a good effect with it without twisting all the way to maximum. Maybe 50-75% can work good.
So, when I am taking some once-in-a-lifetime landscape shot, I do bracketing of exposure and also the polarizer (50%-75%-100%). Then I pick the one that I like best.
---Bob Gross---
shniks
Joined Jan 2004
Jan 06, 2005 21:33 |  #9
I think a polariser is a must if taking landscape shots. I would definitely recommend one. Colours are more saturated and more pleasing. I have a G5 and I have a really good comparison example, settings were exactly the same, taken seconds apart.
Without polariser:
With polariser:
Mike ­ Panic
Joined Jan 2005
Jan 07, 2005 05:47 |  #10
^^ for the above shots i think you would have got a better result from an ND filter
i use my cp filter pretty often... mostly outdoors when im looking to saturete an already blue sky just a bit more, or when im shooting at angle to water or glass that i want to be able to see thru
MikePanic.com (external link) photography | web design | social media | content creation
CripsyHundos.com (external link) instagram photos for your viewing pleasure
Jon
Joined Jun 2004
Jan 07, 2005 08:53 |  #11
No, ND wouldn't have taken out/down the reflection off the water or the leaves. Would have made a longer exposure possible, perhaps, but you'll notice that the greens are more intense in the shot with polarizer, and there's less reflection off the wet rock in the foreground and from the tree branches extending across the creek.
Jon
Cocker Spaniels
FlyingPete
I am immune
Joined Oct 2003
Jan 07, 2005 13:24 as a reply to  @ Mike Panic's post |  #12
I thought a ND was only good for reducing the light levels to achieve narrower depths of field or slower shutter speeds, the actual contrast saturation not affected, with the exception of graduated ND's.
Peter Lowden.
Bodryn
Joined Jul 2004
Jan 07, 2005 20:24 |  #13
I went into a Future Shop one day awhile back (Canada) and asked if they had an attachment for my Canon S1 IS so I could use a circular polarizer. He said they didn't carry that in stock but suggested I might obtain the same effect using a good photoediting program like Adobe Photoshop saying they would have a polarizing filter built into the software. :rolleyes: Naturally I was incredulous so I grilled him further about this to see what he knew about it. After a bit he relented and admitted he had never used it and couldn't answer my questions on it.
Moral? Maybe it's that you shouldn't believe what they tell you in a store that's trying to sell yo something?? But it was lots of fun seeing him try to squirm out of that one. :lol:
Bodryn ========
1,998 views & 0 likes for this thread, 8 members have posted to it.
1110 guests, 124 members online
