So we’re on vacation on Hilton Head Island, just getting used to my new 5D. I was out shooting with the 24-105 - twilight to early evening. The 24-105 had been on the camera since they both came out of the box.
The temperature was probably 86 degrees. Not hot, but fairly high humidity.
I’ve got my 17-40 with me, so I switched lenses. No problem with that. The 17-40 is awesome with full frame, BTW. When I’m done, I go back to our rental house, which has the A/C running on high. The temperature in the house was in the low 70’s with, I presume, low humidity.
The next night, we head to the beach to shoot the sun going down. Basically the same outside conditions, so I put the camera in a plastic bag for about 10, to adjust to the temperature change. When I took it out a tiny bit of condensation formed on the lens, but dissipated within 1 minute or so.
So, here comes the problem: the mirror fogged & would not clear. I finally gave up after about 45 minutes. When I got back to the house, I took off the lens & used the rocket blower on the inside. The mirror finally cleared.
Here’s what I think happened: When I changed lenses outside, the night before, I trapped high humidity inside the camera. During the next day, the air inside the camera cooled (but not enough to develop condensation). Next night out into the heat, I get condensation inside the camera that won’t go away (even after a controlled move from cold environment to hot).
Does this make sense or have I got the science messed up?
If so, it adds another issue to the condensation problem. May one needs to switch lenses in a cold environment after switching in a hot, humid one.
Sorry for the long post. Maybe others will learn from my mistake.
