Thread started 28 Jun 2008 (Saturday) 00:42
Max memory card capacity for IXUS 800 IS
rho08
Jun 28, 2008 00:42 |  #1
Ive got an IXUS 800IS cam n am looking out for a higher capacity card (presently am using it with 1gb sd card). Whats the max capacity card which would be compatible with the cam without putting load on it?
Also, will the micro sd-hc card (with sd adapter) work properly with the cam?
thanks.
Jon
Joined Jun 2004
Jun 28, 2008 07:51 |  #2
The SD800 takes SDHC cards, so there shouldn't be a physical limit. As to "putting a load" on the camera, what do you mean? Battery? Slow down with lots of files?
Jon
Cocker Spaniels
rho08
Jun 29, 2008 11:02 as a reply to  @ Jon's post |  #3
yes i meant to ask bout the slowdown thingy with lots of files getting filled up in the card. thanks.
Jon
Joined Jun 2004
Jun 29, 2008 11:12 |  #4
Haven't seen tests on that particular camera, but tests on DSLRs show that at least when going between comparable 4 GB and 8 GB cards, the 8 GB cards are slower.
Jon
Cocker Spaniels
rho08
Jun 30, 2008 03:30 |  #5
thanks alot for helping out! Ill probably checkout for a 4gb card. :)
3,305 views & 0 likes for this thread, 2 members have posted to it.
2260 guests, 130 members online
