Pinto wrote in post #5811339
Thanks FlashZebra. Is this from personal experience, or your thought on how to approach it, because I'm not sure the metal on the shoe is thick enough to file to the correct angle without cutting through. I thought I would probably disassemble the the shoe and file the plastic base down. I just need it to hold the flash base securely because I'm using an off camera cord for flash sync. Thanks.
Do you mean "personal experience" with this exact setup? If so - the answer is. I have absolutely no experience.
If you mean "personal experience" in a more general way with a human that deals with all sorts of shoes and hotshoes daily. Then yes, I have all sorts of experience.
Unless that metal piece on the bottom is only a few thousands of an inch thick, you are not filing through anything, just make the leading edge a 45 degree angle, not a dead sharp 90 degree stop.
A little bit of lead in and a bit of oil will go a long way.
If it is one of those very thin metal shim like things on the base, just remove the shim and store it.
Butting up against a dead sharp edge is a tough situation.
How are you using an "off camera cord" on a 580EX sitting on a shoe without any contacts?
Enjoy! Lon
