I have the tripod in the following link. What would I need to do to add a ball head to it?
http://www.walmart.com …uct.do?product_id=5030904![]()
ChadAndreo Goldmember 1,879 posts Likes: 15 Joined Nov 2006 Location: WPB, FL More info | Jun 29, 2008 03:50 | #1 I have the tripod in the following link. What would I need to do to add a ball head to it? Photographer + Cinematographer
weemannie Goldmember 2,530 posts Joined Apr 2005 Location: Scottish Highlands More info | Jun 29, 2008 04:56 | #2 Hard to tell from the details in the link. Can you remove the existing 3 way head? If you can, then you should be able to add a ballhead. Regards, Trevor
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jun 29, 2008 05:20 | #3 bimmeracer3 wrote in post #5813211 I have the tripod in the following link. What would I need to do to add a ball head to it? http://www.walmart.com …uct.do?product_id=5030904 A tripod like that does not have a removable/replaceable head. Skip Douglas
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Jun 29, 2008 07:53 | #4 In my experience the legs supports that are attached to the center column on these cheap type tripods are very weak.
Kimberwhip Member 223 posts Joined May 2008 Location: Phoenix, AZ North valley More info | Jun 30, 2008 03:45 | #5 I almost lost my Rebel XT to a Walmart tripod. I caught it inches from the ground after one of the legs unlocked itself. I took the camera off the tripod and walked the "tripod" to the alley and chucked it. It is not worth losing your expensive gear. Canon 40D
R-C-G Member 109 posts Joined Mar 2008 Location: Portland, OR More info | Jun 30, 2008 04:01 | #6 To answer you question, yes you can. Most likely configuration would be to attach the ball head to the original head with a 1/4 to 3/8 adapter. However I'm going to have to echo the previous responses, I would barely trust my camera on one of these let alone with the added weight of a ball head. If your going to invest in a ball head do the right thing and invest in a good set of legs too. gear
| Latest registered member was a spammer, and banned as such! 2717 guests, 158 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
