What are the best techniques of black and white conversion?
Thanks.
FellipedePaula Senior Member 438 posts Joined Jan 2008 Location: Brazil More info | Jun 30, 2008 23:13 | #1 What are the best techniques of black and white conversion?
bieber Goldmember 1,992 posts Joined Dec 2006 Location: Bradenton, FL More info | Jul 01, 2008 01:04 | #2 I've always found splitting channels to work the best. You can also convert to Lab color, and use the L channel, but it never seems to work as well for me... EOS 20D w/ BG-E2 grip
Jul 01, 2008 08:30 | #3 I use Lightroom, but I believe the same/similar technique is available in CS3. In LR if you use the Grayscale menu the image will become B&W and you will see a bunch of sliders, one slider for each color. You can slide these sliders back and forth to increase or decrease the tonality of that underlying color in the image, but there is a better way. In the upper-left corner of the menu there us a little dot with a small up and down arrow above and below it. It's easy to miss so if you didn't know about it you might not ever see/use it. When you click on it your cursor now becomes a dynamic tool to use on the image itself. So now if you see a tone in the image you want to change it's just a matter of putting the cursor on that tone, hold down the left mouse key, and drag forward to lighten the tone or back to darken it. So now you just go around the image changing the tones in this manner until you get what you want. Notice that the appropriate sliders will slide back and forth as you do this. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Rodreguez Senior Member 317 posts Likes: 3 Joined Oct 2006 Location: Bournemouth More info | Jul 01, 2008 09:32 | #4 Alien Skin Black and White plug in! Allows you to choose from a whole load of template settings that emulate traditional monochrome film. With a bit of a tweak you can get amazing results! View mein website:
hommedars Member 235 posts Likes: 1 Joined Jul 2003 Location: PA USA More info | Jul 01, 2008 12:26 | #5 Rodreguez wrote in post #5827204 Alien Skin Black and White plug in! I visited the Alien Skin web site, but they do not show a "Black & White" plug-in. Are you using "Exposure 2"?
| Latest registered member was a spammer, and banned as such! 2625 guests, 154 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
