Thread started 01 Jul 2008 (Tuesday) 13:55
Will the canon battery charger work overseas?
bad ­ karma
Jul 01, 2008 13:55 |  #1
I am living in the US but am taking my charger overseas to India. I looked up the volts they use and they use 240V and 50Hz. The canon battery charger does give a input range (written on the back of the charger) from 100-240V and 50/60Hz.
So I just wanted to be sure if it would be okay, I always double check.
Any input appreciated greatly!
Website: http://www.solsticeret​ouch.com (external link)
Contact: ratik@solsticeretouch.​com (external link)
Retouching classes: http://www.retouchingc​lasses.com (external link)
breadandbutter
Jul 01, 2008 14:00 |  #2
No worries. You'll be fine. Make sure you have an adapter for the prongs.
It's a good day if I'm looking down at the grass and not up at the roots.
Kevin
inthedeck
Jul 01, 2008 14:07 |  #3
Yeap...all you'd need is a 'converter' so that the pins match up to the outlets there. That's what I did, and was glad I invested the 12 bucks for a converter.
MCSquared Photography (external link) on WWW
MCSquared Photography (external link) on Flickr
MCSquared Photography (external link) on IG
My name: Manish.
bad ­ karma
Jul 01, 2008 14:17 as a reply to  @ inthedeck's post |  #4
Gotcha! I'll definitely invest in the converter, thank you all.
gjman
Jul 01, 2008 16:34 |  #5
You don't need a converter you need an adapter (as you correctly pointed out the charges is capable of 110/220 @ 50/60hz so it works pretty much anywhere). If you have US style Type A plug (NEMA 5-15) you need an Type C adapter (CEE 7/16) plug so that you can plug it into the Indian wall socket. And B&H sells its ;-)a
http://www.bhphotovide​o.com …P_USA_E_Adapter​_Plug.html (external link)
IMAGE: http://www.bhphotovideo.com/images/largeimages/483049.jpg
I wonder how long I have to hang out on POTN before I get as good as Ansel Adams ?
1,856 views & 0 likes for this thread, 4 members have posted to it.
2717 guests, 158 members online
