Thread started 01 Jul 2008 (Tuesday) 16:42
fill flash: how to meter?
prinspaul
Jul 01, 2008 16:42 |  #1
hi,
I was wondering how you guys set your camera and use your speedlight as a fill flash.
Suppose I have to make a group shot outside at a normal sunny day at M-setting: 125th f8, iso 100/200.(like normal) Do I have to meter my camera at 0 (for ambient light / background) and set FEC around -1? or should I underexpose my camera lilttle bit and 'play' more with the flash?
is there a nice rule of thumb?
thanks in advance!
gofer
Jul 01, 2008 17:08 |  #2
prinspaul wrote in post #5829727 (external link)
hi,
Nice sunny day - Av mode, aperture F8, ISO 100, no FEC, Press the shutter button.
Steve.
Curtis ­ N
Master Flasher
Jul 01, 2008 19:07 |  #3
I would go with 1/250 and f/5.6 instead, to give you better flash range. Pay attention to the distance scale on the back of the flash after you zoom the lens. You'll see the difference.
0 FEC should usually work if the ambient is slightly underexposed.
There is not really a "rule of thumb" because it all depends on the lighting. Practice and experiment.
prinspaul
Jul 02, 2008 12:00 |  #4
great! thanks.
I always try and see what is best, but I was wondering if there was a better way to start with..
Curtis N, thanks for you comment. but do you mean I have to start with 1/250 and then see what my aperture will be? or is it just a reference to my example and the sunny 16 rule?
cdifoto
Don't get pissy with me
Jul 02, 2008 12:03 |  #5
You're overthinking it. Just meter for your background, fire a shot, chimp, then adjust FEC as needed for the subject.
Curtis ­ N
Master Flasher
Jul 02, 2008 19:46 |  #6
prinspaul wrote in post #5835197 (external link)
I just took the example exposure settings you used and shifted it, for a faster shutter, wider aperture and the same net exposure.
You'll reduce the chance of motion blur with the faster shutter and increase the range of the flash with the wider aperture.
luigis
Jul 02, 2008 20:08 |  #7
The flash is in fact a fill flash, so expose the backgroud correctly and just put the flash in TTL mode, it will take care of your subject. With this technique you only need to adjust in about 20% of the shots you take as cdifoto mentioned.
There shouldn't be motion blur with the subject the flash is faster than that and will freeze the subject. Just take care of the background.
Luigi
www.luisargerich.com (external link)
Landscape Photography & Astrophotography
My Awesome Gear List
prinspaul
Jul 04, 2008 16:56 |  #8
thanks for all the comments, "taking care of the background" was my 'menthod' indeed! but it's nice to read your answers and hints!
TMR ­ Design
Joined Feb 2006
Jul 04, 2008 22:22 |  #9
Curtis N wrote in post #5830475 (external link)
And doing as Curtis suggests also creates some very nice effects by underexposing the background by 1/3 or 2/3 stop and letting the flash fill in the subject area.
Robert
sfaust
Jul 05, 2008 00:57 |  #10
You mentioned you were shooting a group, so I would also monitor your depth of field since 5.6 could be shallow enough to render someone in the front or rear a bit out of focus depending on the distance and lens used.
Stephen
Mix of digital still gear, Medium format to M4/3.
Canon EOS Cinema for video.
Commercial Photography (external link)
Kippei
Jul 06, 2008 12:20 as a reply to  @ sfaust's post |  #11
I usually go with TV mode. I can't get x-sync speed with AV mode coz it is that sunny.
gore
Jul 06, 2008 22:31 as a reply to  @ Kippei's post |  #12
Like some others suggested - for quick results you set exposure (best in Manual mode) for background and set flash to E-TTL. Try - background will be properly exposed (because you set it :p). The subject's exposure can be changed via FEC (+ or -). And here we go ...
I write some basic stuff about using flash on my blog (http://kacnje.blogspot​.com …sh-system-simple-way.html (external link))
http://kacnje.blogspot​.com (external link)
Scott ­ B
Jul 06, 2008 23:01 |  #13
When we're metering for the background ... are you metering off the sky, trees, grass or what? (Sorry for such a basic question.)
Jaysee&Dali
Jul 07, 2008 01:17 as a reply to  @ Scott B's post |  #14
I write some basic stuff about using flash on my blog (http://kacnje.blogspot​.com/2008/06/c...imple​-way.html (external link))
gore,
Cheers for the link! :D
I've just got the 430EX for my 40D and am still getting my head around how it works. The info on your blog is clear and importantly, easy to understand!
cheers,
J&D
Canon EOS 6D | 50mm f/1.4 | 17-40mm f/4 USM | 24-70mm f/2.8 L USM | 100mm f/2.8 L IS USM | Canon 135 f/2 L USM | 70-200mm f/4.0 L USM IS| 400mm f/5.6 L USM | Canon EF 1.4x II Extender
Jaysee&Dali 1.0 (external link) on flickr
gore
Jul 07, 2008 11:52 |  #15
Scott B wrote in post #5862575 (external link)
Just meter from the object you want - and make that object exposure you want (I have some simple instructions on this also on my blog, but maybe you can find better explanation). In simplest example - power off falsh and meter from gray object in background and the exposure is now right (for our example). If you are not in M(anual), set metered value in manual (both shutter and apperture). Then power on flash and try with 0 (auto, without FEC). You will see - background is the same as before, foreground will be exposured from flash (depends on many thing - distance ...). If you want more bright foreground, set +1/3 ... or +1 ... or +2 on your flash! And opposite.
Clear? If not, just ask.
2,846 views & 0 likes for this thread, 13 members have posted to it.
1315 guests, 124 members online
