PacAce wrote in post #5834961
But I thought you said that the off-camera flash was your main light and your on-camera flash was just being used for fill. If that were the case, then surely you would have set up the off-camera flash so that it would give you the proper main light exposure since getting that right would be more important than getting the fill light right (as long as the fill light is just that and doesn't overwhelm the main light).
Leo - I am not sure I understand your confusion as you seem to be knowing more about my setup than myself
You are right the - off camera flash is the main light and is set at a position which doesnt make the subject too bright. The 430EX provides fill light which evens out the lighting and corrects exposure. Without the 430EX firing, I assume (as the 430EX or atleast camera flash HAS to fire to trigger the off camera flash I cant test this) that the light provided by the off camera flash would be harsh with deep shadows and incorrect exposure. My point is that the combination of the flashes even out the lighting making it easier for me to get the image. Using only one of the flashes would require me to get in to full manual mode - moving flash, diffusing, experimenting etc.
Thanks Lon - I DID read that thread some time ago - but I think I need to revisit again - thanks for the reminder
Titus213 wrote in post #5836122
Any chance we could get a sample picture using this combination of flashes?
At the moment I dont have any pics of the setup, but will try to get some during the weekend and post here.
The 430EX on the camera is measuring the available light with the pre-flash. That available light includes the remote. If you just pressed the shutter button the pre-flash from the 430Ex would trip the remote flash and it wouldn't recycle fast enough to take the picture. By pressing the * button you are giving the off camera flash time to recycle. Clever but I would think it would eventually cause problems with improper lighting.
EXACTLY what I am doing and acheiving. So far, I have been able to get good results but now that I am thinking of moving the 430EX as an off camera flash, I might have probs with improper lighting so experiments are in order. But with regard to the triggers, the optical trigger still seems to be the option for me.
