Thread started 03 Jul 2008 (Thursday) 17:19
how does my future 40D kit look? and what am i missing?
aparis99
Jul 03, 2008 17:19 |  #1
OK, i've narrowed it down and think i've done enough reading to be sick. Im on a budget so keep that in mind here, no $1000+ L lenses for me just yet....
Body ----- Canon 40D -- $940
WA ------- Tamron 17-50 f/2.8 -- $450
Prime --- Canon 50 f/1.8 -- $ 90
Tele ----- Canon 70-200 f/4L -- $560
Sandisk Extreme IV 4GB -- $50
Total so far: $2090
I wanna shoot all types, so will this suffice for awhile? What about any other real necessities? grip, flash, macro lens, etc will be down the road.
Which backpacks/bags do you all recommend for this setup? maybe some room for cables, mem cards, some random odds and ends?
Also, if ur against anything i've selected, tell me why, and gimme an alternative. THANKS
My Site - www.apimagery.com (external link)
Canon R5 (x2), Canon RF 15-35 f/2.8L IS, Canon RF 24-70 f/2.8L, Canon RF 70-200 f/2.8L, Canon RF 100-500L, Sigma Art 35 f/1.4, Canon 85 f/1.8, Canon 100 f/2.8L Macro
wimg
Jul 03, 2008 17:29 |  #2
aparis99 wrote in post #5844056 (external link)
Total so far: $2090
That's a very fine starting set. Personally, I would add a second 4GB memory card, so as to put not all of your eggs in a single basket.
Backpack: LowePro MicroTrekker; bags another LowePro AW, or maybe a Crumpler. You'd have to check what you'd prefer yourself; there are too many choices. :D
Kind regards, Wim
sadowsk2
Jul 03, 2008 17:33 as a reply to  @ wimg's post |  #3
perhaps think of getting either a Sigma 10-20 or Canon 10-22 to round out your ultra-wide capabilities,,
1D Mk IV, 5D Gripped, 30D
35L | 50L | 85L II | 100L | 135L |16-35L | 24-70L |[COLOR=black] 24-105L | 70-200 2.8L IS II | 100-400L | 15mm fisheye | 580EX II x2 | 430EX
Canon S3IS
homersapien
Jul 03, 2008 17:45 |  #4
That's an excellent start. Recommending bags is tough...there's no single back that can do everything, and not everyone uses bags the same way. For example, my main photo bags are:
Mountainsmith hip pack
REI backpack
Arc Teryx backpack
Canon 200EG photodelux backpack
The Canon is a must have, and it's the only gimmick/photo specific pack I'll buy. I use it year round and for anything up to 5/6/7 miles. But for more strenuous stuff, nothing beats a REAL backpack.
Cyrus
Joined Oct 2002
Jul 03, 2008 17:48 |  #5
sadowsk2 wrote in post #5844140 (external link)
That's exactly what i just did yesterday :)
form
"inadequately equipped"
Jul 03, 2008 17:49 |  #6
Ditch the 50mm f/1.8 II and buy a few spare batteries from www.sterlingtek.com (external link) - they sell them single or in pairs.
Buy those lenses used and save over $100 between the two; then use that money and the money you saved by not buying the 50mm f/1.8 II and buy a 50mm f/1.4, or spend a little more for a 85mm f/1.8.
You can find Tamron 17-50 used for around $350 if you're patient (currently popular alternative is the Sigma 24-60 f/2.8 for about $200), and 70-200 f/4L for around $500 or less.
70-200 f/4L for $480: http://sfbay.craigslis​t.org/sby/ele/74038429​6.html (external link)
Las Vegas Wedding Photographer: http://www.joeyallenph​oto.com (external link)
FlyingPhotog
Cream of the "Prop"
Jul 03, 2008 17:50 |  #7
Take a look at the Lowepro Slingshot series.
You'd fit fine in a 200AW but the 300AW would allow for a little more growth room. I can get my 40D + Grip + 70-200mm f/2.8L IS easily into the main compartment. (Fits fine too with a 100-400mm f/4.5-5.6L IS mounted as well. Just reverse the lens hoods and turn the body 90 degrees so your CF slot is facing up.)
Jay
Hermeto
Jul 03, 2008 18:02 |  #8
For this setup, I recommend Lowepro Slingshot 200AW too.
darkninja67
Jul 04, 2008 00:14 as a reply to  @ Hermeto's post |  #9
Slap a Tokina 11-16mm f2.8 into the mix and call it a day.
Bill
Canon 40D gripped, Tamron 17-50mm f2.8, Sigma 24-60mm f2.8, Tokina 50-135mm f2.8, Feisol CT-3442 w/ Manfrotto 488RC4 ballhead, Manfrotto 679B monopod
ChrisRabior
Jul 04, 2008 00:23 |  #10
To be honest, I don't use my 50mm f/1.8 at all. Just not intelligent enough for my low light work. I'd say skip the 50mm f/1.8, and look for a 1.4 or 1.2. If you're set on a prime, the 35mm f/2.0 is a good bet, and can be found for about $240 (probably the second cheapest prime you'll find).
If the money is an issue, skip the 50 and stick w/ the rest of your kit. What you mentioned will be a VERY good starting point for you. Treat the absence of the 50 as one step closer to your macro or whatever else you're planning on next.
My Gear | My Alamy (external link) | My Website (external link) | MMA Photography (external link)
Zander ­ Albertson
Jul 04, 2008 00:32 |  #11
Instead of 1x 4GB. look at 2x 2GB.
If you're not shooting sports a bunch, look at Ultra II CFs instead of Extreme IV... save some more $
Editorial Photographer, Canon Digital.
blary54
Jul 04, 2008 00:43 as a reply to  @ Zander Albertson's post |  #12
Get the kit with the 28-135 IS...this is normally a $400 lens that you can get for 200 if you get the kit. Very worth it and an excellent range if you ever put it on a 5d. Plus you will have at least one IS lens then.
Also I would get the brand new Tokina 11-16 2.8f ($570) Excellent reviews on this. Although it just came out and will hard to find.
http://www.bhphotovide​o.com …_16mm_f_2_8_AT_​X_116.html (external link)
I would also recommend a Manfrotto 055 tripod with ball head but thats around $270.
At least buy a monopod. This is the one I have and love it $35.00
http://www.bhphotovide​o.com …6B_676B_Digi_Mo​nopod.html (external link)
(you may want to buy the $20 ball head add on)
Good luck. I just recently was inthe same boat as you:
I ended up buying the the 40d kit with the 28-135 IS
the 100mm Macro, 50 f1.8 and then the monopod I listed above and a Tamrac adventure 6 backpack. $1800.00
~Brian
Canon 40D
EF 100mm f/2.8 Macro
EF 28-135 IS
EF 50mm f/1.8
Tokina 11-16 f/2.8
ps249
Jul 04, 2008 00:44 |  #13
Your missing the most famous lens of all: Canon 100-400 IS . . . . . . . .
40D
50 f/1.8 | 28-135 IS |
MAUREEN SOUZA FOR PRESIDENT!
Stuperfox
Gallery: 12 photos
Jul 04, 2008 01:17 |  #14
Don't get a grip unless you want to miss it when you don't have it. I still need to get mine and I am missing it more and more now. I will get it tomorrow I think. They are really that nice.
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
Big ­ WIll
"Slight breach of etiquette"
Jul 04, 2008 01:22 |  #15
Have to agree with Zander, look away from the Extreme IV and look at the Ultra II's or Extreme III. Unless your shooting for sport and need the speed.
Computers blur the boundaries... We are being released from the suddenness of photography, the suddenness of the shutterhttp://www.photography​-on-the.net …p?p=1606920&pos​tcount=132
2,530 views & 0 likes for this thread, 23 members have posted to it.
1458 guests, 137 members online
