Thread started 03 Jul 2008 (Thursday) 22:56
First shot with my Bees....!
sidx001
Jul 03, 2008 22:56 |  #1
Ok, my Bees arrived today and I promptly coreced my daughter to help me test them! I set up a back drop in the living room, placed both B800s about 12 feet from the back drop and set them at a height of 6'. Both bees have umbrellas on them, one reflective to the right of my daughter. Camera was at f7.1, 250 and 400 ISO. Both bees were at about 1/4 power.
I think the lighting is good, although I'm seeing some shadow on the bottom right and left...probably because of the heighth of the lights. Critique please?
James Smith
https://photography-on-the.net/forum/showthre​ad.php?t=586230
Lotto
Jul 04, 2008 02:04 |  #2
Congrats on the Bees. The B800s have plenty of power, use iso100 for now for best IQ. Also the lighting looks a bit flat, try set the fill light a stop or 2 less than the main.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
tim
Light Bringer
Jul 04, 2008 02:05 |  #3
I'd go with a bigger ratio (maybe 1/4 on one and 1/8 on another), that'll make the lighting a little more interesting. Also I can see too much of the background, i'd put hre further away from it and use ISO100, F3.5 (guess), and change your shutter to 1/125th just in case you run into issues some time. Shutter speed's irrelevant when you're in the studio, just for kicks set it to 1/10th and see what difference it makes.
Gatorboy
Jul 04, 2008 07:31 |  #4
You want the lights as close to the subject as possible -- the closer the lights, the softer the light will look.
I also agree with the others on the flatness of your image -- you need to have one light brighter than the other.
Dave Hoffmann
TMR ­ Design
Joined Feb 2006
Jul 04, 2008 07:57 as a reply to  @ Gatorboy's post |  #5
Highlight and shadow are what will give an image dimension and contrast. For right now I wouldn't worry about patches of your background that are slightly bright or dark. I would concentrate on modeling the face, creating highlights and controlling shadow, but not eliminating shadow.
Robert
AB8ND
Jul 04, 2008 08:54 |  #6
My only suggestion to add to the others is to pull her away from the background. A rule of thumb, can't remember where I heard it, is subject to background at least same as subject to camera.
Jack
sidx001
Jul 04, 2008 15:33 |  #7
Thank you everyone for the comments, I'll put everything back together probably tomorrow night as tonight I'm shooting fireworks. Thank you for the input! I love the Bees!
James Smith
Ray ­ Marrero
Gallery: 23 photos
Jul 05, 2008 21:56 |  #8
get some space between subject and the background, use wide f-stop to blur out the background a bit, keep the light very close to subject. low iso, 100 or 200. keep shooting.
Ray
Canon 6D, 7D, 30D, Flashpoint Zoom Li-on R2 x2, Flashpoint eVOLV 200 and XPlor 600, AB800 x3, Canon 10-22mm, 18-55mm, 50mm 1.8, 85mm 1.8, 24-70mm 2.8L, 24-105mm 4.0L, 70-200mm 2.8L IS, Sigma 28-105mm 2.8, Tamron 28-75mm 2.8, CyberSyncs.
1,144 views & 0 likes for this thread, 7 members have posted to it.
2532 guests, 157 members online
