Thread started 04 Jul 2008 (Friday) 20:36
help with tips for shooting with flash in full manual
troypiggo
Jul 04, 2008 20:36 |  #1
I have a 430EX and to date have only shot in E-TTL mode. For the most part I'm happy with the results, but I'd like to start experimenting with the flash and manually controlling the power. I figure I shoot with the camera in full manual, I should teach myself manual flash too.
Pretty sure I understand the concept of guide numbers (GN):
(GN) / (focal distance to subject) = (f-stop to set camera if ISO100)
My 430EX has GN of 43 at ISO100 and zoom 105mm.
If increasing the ISO the GN doubles every 2 stops of ISO, so eg:
(ISO400 GN) = 2 x (ISO100 GN) = 86 for my 430EX if shooting ISO400
Not sure at this stage how/where the 105mm zoom fits in to these equations.
I assume the above is based on full power. If I decrease power by a half, the distances will halve if keep the same f-stop, or keeping distances same the f-stop will have to widen accordingly. And adding things like flash diffusers reduce stops as well, so adjust accordingly for that too. Think I get it.
How accurate are the GNs and formulae for things like shooting macro? Dealing with focusing distances or 300mm or less. Typically if I'm using ISO200, f/11, and 1/200s and reverse engineer the GN formula:
43/.3=143 so need f/143 at full power and ISO100.
Adjust power down to aperture f/11:
11/143=1/13 of full power <- not sure about this assumption
And adjust because using ISO200:
1/13x1/1.4=1/18 power. Then I'd have to round off to nearest power setting, probably 1/16 (can't check now, don't have flash with me).
That sound right? Am I overthinking this? Should I just stick with E-TTL for macro stuff? I was expecting that 1/64 power would be enough for things so close (assuming no diffusers or extension tubes taking stops away).
Any good links for this? (Other than strobist)
"Interesting. You're afraid of insects and women. Ladybugs must render you catatonic." - Sheldon
Flickr (external link) | Gear List | Macro Rig | Astro Rig | Astro Software Post
PacAce
Joined Feb 2003
Jul 05, 2008 07:46 |  #2
troypiggo wrote in post #5850703 (external link)
You on the right path as far as your understanding of how the GN works. Working with a GN table for the 430EX would make like a little less complicated for you, though. Here's the GN table from page 34 of your 430EX manual:
Just select the GN from the row that specifies the flash head zoom position and the column that specifies the flash output you are using. For example, if your head is set to the 50mm position and you have the power level set to 1/8, then your GN would be 12m or 39.4 ft. :)
BTW, the GN specified by the manufacturer is just a guideline because it assumes a certain amount of light being reflected by objects in the surrounding environment such as walls and ceilings. In other words, the actual GN would be different when using the flash indoors and when using it outdoors since usually there are no reflecting surfaces outdoors.
...Leo
Curtis ­ N
Master Flasher
Jul 05, 2008 08:29 |  #3
Guide numbers used to be simple.
Nowadays, using them is complicated, for a couple reasons:
1) Your flash has eight different guide numbers, one for each of the zoom settings.
2) Your camera has fourteen different ISO settings.
So when you combine those two factors, you'll be working with 112 different guide numbers, before you even begin to figure in the aperture.
Make life easy. Look at the distance scale on the back of the flash unit and call it a day.
:D
PacAce
Joined Feb 2003
Jul 05, 2008 08:34 |  #4
Curtis N wrote in post #5852777 (external link)
:D
That'a very good advice, Curtis, and one that I would ordinarily give myself except in this case, it may not be too applicable for macro work. But, having said that, I'm not too sure how well the GN chart would apply for macro work either. :| Hopefully the OP will find out and let us know. :)
...Leo
Wilt
Jul 05, 2008 09:24 |  #5
Flashes do not care about macro distances (unless they cannot reduce power enough)...the effective aperture of the lens is what governs things...1:1 repro ratio is 4x the exposure, 1:4 to 1:3 repro ratio is 2x the exposure, for example. Using manual flash, you need to calculate the effect of extension tube on your exposure, because the aperture has changed, not the flash.
GN doubles (or halves) with a 4x change in power...so if full power is GN43 in meters, 1/4 power is GN11. I would prefer using GN rating in feet, not meters, since the units are more convenient to macro work! A GN160 flash would be GN40 at 1/4 power, GN10 at 1/16 power, and GN2.5 at 1/64 power. So if you are shooting 1.25 feet away at 1/64 power, that is f/2 aperture with no extension, and f/4 at 1:1 repro ratio. And in using manual flash, I would base everything on a single zoom setting like as wide as it can cover, to make thing easier. (You seldom have a problem with too much power at macro distance!) And calculate for ISO 100, then merely alter the aperture arithmetic in your head when you use faster ISO...going to ISO1600 would take the f/4 setting at 1:1 to f/16, simple isn't it?!
ETTL is your friend...if your flash can regulate itself down to 1/256 power, it can do that in ETTL mode or in M mode, and the end result is the same, just less work! ETTL will compensate for changes to the effective aperture much more simply than calculations in your head with Manual flash
PacAce
Joined Feb 2003
Jul 05, 2008 12:27 |  #6
Wilt wrote in post #5852994 (external link)
I agree that the flash does not care about the macro distance. However, I think that the photographer should care. In my previous post, I said that the GN for the flash will differ depending on whether the flash is used indoors in an average-sized room or outdoors where there are no surfaces like walls and ceilings there the stray flash light can bounce off and get redirected towards the subject. That would also apply to macro distances. If the macro subject is not inside an enclosure, there may be no surrounding surfaces to bounce stray light back at the subject and hence, would be like taking a picture outdoors even though the macro subject may be indoors. According to my tests, there could be as much as a stop less light reaching the macro subject if the GN calculation is done based on the published GN without adding any compensation.
Of course, if the flash is only being used for fill, this would be less of an issue.
...Leo
Wilt
Jul 05, 2008 12:31 |  #7
PacAce wrote in post #5853891 (external link)
No debate about the point raised!
Lotto
Jul 05, 2008 13:50 |  #8
ETTL can reduce the flash output lot lower than manual mode at minimum. With iso200, f11, and the 430 zoom to 105mm and 1/64 power, the flash needs to be atleast 8" from the subject to get the right exposure. With ETTL, the flash can be placed right on top of the bugger and zap it :)
5D, 24-105L, 70-200L IS, 85mm Art, Godox
PacAce
Joined Feb 2003
Jul 05, 2008 14:58 |  #9
Yes, I agree with Wilt and Lotto. ETTL would probably be the better choice for macro flash photography in most circumstances but especially when using more than one flash.
...Leo
troypiggo
Jul 06, 2008 15:54 |  #10
Thanks for all your tips and input guys.
I've been thinking about it more. Another point to not that I don't think was mentioned above is that since distances with macro are so small, you won't have to be out much with the distance calculations to have severely too much or little flash. I mean, you move back and forth millimetres or tens of millimetres while focusing or composing the shot. Over 300mm working distance 10mm is 1/30.
But for "normal" flash photography the distance you actually take the shot compared to the distance you calculate flash power for will be practically the same.
I'm thinking as Lotto suggests, since ETTL can output much lower than 1/64 manual capability, that for macro work I'll continue using ETTL. For interest sake, I might do some testing but suspect I won't like the results :)
I'll continue my pursuit of full manual flash knowledge for normal photography for which the flash was originally designed :)
Hangerhead
Jul 07, 2008 09:54 |  #11
maybe a little simplistic (on my part) but wouldn't manual flash be of more benefit if what you are shooting is:
background is constant (like portraits) but the subject is changing (more/less flash reflective).
so for example, if i ever got into doing portrait shots, I'd set my camera up to expose for a background and then use a light meter (or a lot of experimentation) to determine tha manual flash settings.
then after that, no matter how many light or dark subjects i shot, the flash exposure would be the same for each one.
err, not sure if i should make that a question instead... ?? :)
www.hangerhead.smugmug​.com (external link)
Canon 1DS MK II, Canon 40D
Canon 70-200mm L f4, Canon 50mm f1.4, Canon 17-55mm IS f2.8, Canon 85mm f1.8, Canon 24-105 IS f4 L, 17-40 L
Wilt
Jul 07, 2008 11:52 |  #12
Hangerhead wrote in post #5864898 (external link)
Hangerhead, you assume too much...that dSLR owners know what a handheld flash meter is, let alone own one! The many, many threads about 'do I need a meter (or can I chimp)?...' and 'handheld meters are I, I have the histogram' illustrate that point.
Hangerhead
Jul 08, 2008 15:34 |  #13
so, by your slightly esoteric reply, i guess my take on it is correct.. :D
Wilt
Jul 08, 2008 17:02 |  #14
Hangerhead wrote in post #5873893 (external link)
Your take is correct, if you not of the school that states "Handheld meter is dead. Long live histograms."
7,252 views & 0 likes for this thread, 6 members have posted to it.
2678 guests, 163 members online
