I can't seem to strike a good balance between rotor blur and sharpness. What shutter speeds do you use?
tsamarin Senior Member More info | Jul 05, 2008 00:22 | #1 I can't seem to strike a good balance between rotor blur and sharpness. What shutter speeds do you use? 30D/ 5D2/ EF 85mm f/1.8 / EF70-300mm/ EF 100-400L/ EF 24-105L/ EF 17-40L/ 430 EX/ 055X PROB/BH-55 & CPL1
Foxgguy2001 Senior Member 355 posts Joined May 2008 Location: Riverside, CA More info | Jul 05, 2008 01:38 | #2 yeah i could see that being difficult.... i think you did well with it though... i like both shots. My humble beginnings: Canon XTI, 17-85 IS, 50mm 1.8
KulmanMJ Member 221 posts Joined Mar 2008 Location: Michigan More info | You do have an excellent rotor blur on these. My guess is that you'll have to sacrifice some of that blur for more sharpness on the airframe. Matt
PhotosGuy Cream of the Crop, R.I.P. More info | Jul 05, 2008 09:27 | #4 What shutter speeds do you use? Every shot is different cause there's too many variables: AC speed, rotor speed, distance, focal length, steadiness of the OP... FrankC - 20D, RAW, Manual everything...
KulmanMJ Member 221 posts Joined Mar 2008 Location: Michigan More info | Jul 05, 2008 09:48 | #5 Good points. I should have at least considered the AC speed. In my shots the heli was in a hover. His heli was most likely in forward flight. Matt
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Jul 05, 2008 10:14 | #6 Any prop blur is good to me. As long as they are not frozen its good.
Jul 05, 2008 12:20 | #7 Thanks for the replies, everyone. I guess I'll play with shutter speeds to see how fast I can go and still have acceptable rotor blur. The thread PhotosGuy linked made me think about turning off the IS completely-that's something else I can try. Gyroscopes? Wow, lemme Google that one; it sounds interesting! 30D/ 5D2/ EF 85mm f/1.8 / EF70-300mm/ EF 100-400L/ EF 24-105L/ EF 17-40L/ 430 EX/ 055X PROB/BH-55 & CPL1
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Jul 05, 2008 12:24 | #8 Use your IS Mode 2 which is meant for panning...
Jay
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Jul 05, 2008 12:26 | #9 They would go where the tripod would. They would spin up and stop any sudden movement and vibrations.
Jul 05, 2008 12:46 | #10 Now that's what I'm looking for, FlyingPhotog. Nice and sharp with enough blur to say "motion." Mine were shot at the Paso Robles Airport yesterdayat 1/60, while I was trying to shoot the CalFire aircraft. No luck with that, by the way. They were using the far runway and the waves of heat rolling off the tarmac distorted everything I shot. Some days, eh? I'm looking at the gyros from Kenyon. It's a neat little package but I'm afraid I'll still get blur from subject motion. 30D/ 5D2/ EF 85mm f/1.8 / EF70-300mm/ EF 100-400L/ EF 24-105L/ EF 17-40L/ 430 EX/ 055X PROB/BH-55 & CPL1
Razor61 Member 126 posts Joined Feb 2007 Location: South West England More info | Jul 15, 2008 13:55 | #11 For helicopters the shutter speed depends on what type of helicopter. Canon EOS 350D
JamieHolladay Cream of the Crop 21,557 posts Likes: 3 Joined Nov 2005 Location: Gadsden, Alabama, USA More info | Jul 15, 2008 21:34 | #12 Razor61 wrote in post #5916126 For helicopters the shutter speed depends on what type of helicopter. You really don't need too much blur, average is enough, don't sacrifice subject quality over rotor blur. Examples:- Bell 212 (Huey) circa 1/30 to 1/125 Chinook - circa 1/125 to 1/200 Lynx or A109 - circa 1/160 to 1/320 Basically, large diameter slow moving rotors need very slow shutter, especially to enable a full disc on the tail rotor, then you are talking about silly speeds. Even 1/30 isn't enough in some cases. This goes for the Bell 212 (Huey). Chinooks aren't too bad, even though their rotors turn much slower than the usual helicopters, they aren't as slow as the Hueys and you don't have a tail rotor as such to sort out either. A109s or that category where the rotors are turning extremely fast you can sometimes get away with 1/320. If the helicopter is coming right at you, then don't bother with rotor blur unless it's taxi-ing. If its in flight coming at you with the rotors head on (in line) then whack it up to 1/500 or above. No rotor blur needed. If its nose down or rotors are pitching down (like during taxy) then use medium shutter (around 1/160) Nice post. The Site
PhotosGuy Cream of the Crop, R.I.P. More info | Jul 16, 2008 07:20 | #13 If the helicopter is coming right at you, then don't bother with rotor blur unless it's taxi-ing. That's much the same as when a prop plane is in profile. Nobody can get a good blur then, so if you need a "safety shot", use a high shutter speed.Then you can practice blurs at slightly different angles all you want & still have a shot to deliver if you fail. FrankC - 20D, RAW, Manual everything...
Jul 16, 2008 11:45 | #14 Great information here. Thanks for the replies! 30D/ 5D2/ EF 85mm f/1.8 / EF70-300mm/ EF 100-400L/ EF 24-105L/ EF 17-40L/ 430 EX/ 055X PROB/BH-55 & CPL1
| Latest registered member was a spammer, and banned as such! 2709 guests, 165 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
