Thread started 05 Jul 2008 (Saturday) 13:12
my 70-200 f/2.8 and Circular Polarizer hate eachother!
cujojpn
Jul 05, 2008 13:12 |  #1
Hey everyone, I have one quick question/rant. Ok usually I have been ordering Sunpak filters from Japan. And I have been getting great results when I use them, hence why I havn't switched to Hoya or higher grade filters. But recently when I bought my 70-200, and popped on my 77mm Circular Polarizer they just hate eachother! But my Sigma 10-20 f/4-5.6 has no issue with that same filter.
Here is an example of the hatred.
That is with the CP filter on the 70-200. No its not loose or anything, it comes out like that, OOF and terible! Really doesnt even do its job with the 70-200, skies remain blown and even becomes less saturated.
Now look at the same shot with the CP off!
So I am wondering if I should just get a higher grade filter? Is it because its L glass and L glass is so much more picky when it comes too what filters will look good. I really do hate walking around with no filter on the glass since it is my most expensive glass and what if it gets scratched!
Kaleb W.
Canon EOS 40D:
Sigma 10-20
f/4-5.6, Canon 24-70 f/2.8 L, Canon 70-200 f/2.8 L, Canon 50mm f/1.8, Canon 100mm f/2.8 Macro
MattMoore
Jul 05, 2008 13:17 |  #2
If your worried about protecting your glass from scratches, why don't you just buy a high quality UV Haze filter?
On more expensive glass (i.e. L), I would definitely recommend using high quality filters (usually much better optics and ring material/construction)​; B+W, HOYA Pro, and Heliopan all come to mind.
What good is all that expensive glass if the first thing the light passes through is of lower quality than everything after it? You went all out on the glass itself, don't cheap out on the filter you put in the front of it.
I use a B+W MRC CPL on my 70-200L f/2.8 IS without any issues whatsoever.
Hit up hvstar.net for good prices on higher quality filters.
Let Sunpak make your aux flashes, not your filters.
NeoTokyo
Jul 06, 2008 02:05 |  #3
I use Kenko Pro 1's with no problems (Not on a 70-200mm though.)
Hoya and Kenko own into the same company and the filters are identical.
If you like to save cash then go with Kenko.
Check out my flickr! http://www.flickr.com/​photos/crainracing/ (external link)
Super-Nicko
Jul 06, 2008 02:38 |  #4
I use hoya CP 77mm thread on my L's (17-40 and 24-70) and on my 100-400 with no problem like shown
I only use the cheaper hoya one - about 70USD - not the 100+$ one.
I dont use it much on the 100-400 as i find its too dark at 5.6 anyways letalone forcing 1 or whatever extra stops of darkness with the CP
My gallery - just posted some of my top shots (external link)
1DmkIII / 5DMKII [50mm f1.4] [85mm f1.8] [100mm f2.8 MACRO] [17-40mm f/4L] [24-70mm f/2.8L USM] [24-105mm f/4L IS USM] [COLOR=black][COLOR=bl​ack][[COLOR=black]100-400mm f/4.5-f 5.6L IS USM] Canon 1.4xII - Speedlite 580EXII - EPSON P-5000 - Lowepro Bags - Manfrotto 682B Monopod & 055XproB Tripod - 488RC2
grego
Jul 06, 2008 03:07 |  #5
Hoya/Rodenstock/B+W/He​liopan are all the filters you should be looking into. You'll spend a decent amount, but you get good quality filters. And 77 will work with other L's like the 16-35.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
Paul ­ Tinworth
Jul 06, 2008 07:24 |  #6
1/40th versus 1/160th.
You need to remember that using a CPL can lose you up to two full stops of light (which is what your EXIF is showing). ;)
~ Paul
Current kit: Fujifilm X-T1 | XF 16-55 f/2.8 | XF 50-140 f/2.8 | XF 56 f/1.2 | XF 80 f/2.8 Macro
Previously owned: Canon 5D Mark II | 40D | 50 f/1.4 EX | 24-70 f/2.8L | 70-200 f/2.8L | 430EX
Paul Tinworth Photography (external link) - Portraits, Weddings, and Events | Gear-list & feedback
cc10d
Joined Jan 2004
Jul 06, 2008 08:29 |  #7
What Paul said, 1/40 is slow for 200 mm, hand held. effective magnification of 320mm on 1.6 crop body.
cc
Paul ­ Tinworth
Jul 06, 2008 08:42 |  #8
cc10d wrote in post #5858278 (external link)
Field of view (aka 'crop factor') as opposed to actual magnification, but I think the point cc10d is trying to get across is that 1/320th would be the nominal shutter-speed for 200mm.
Bump up that ISO, good sir! :D
~ Paul
Wilt
Jul 06, 2008 09:33 |  #9
As has been pointed out, the CPL loses light, so you must use a slower shutter speed (or larger aperture) to counterbalance that loss. If you use 1/40 on a 200mm lens hand held, that is far far less (in fact, 10x less!) forgiving than 1/40 on a 20mm lens.
The filter does not hate the lens, your shaking hand hates the slow shutter speed!!!
SkipD
Joined Dec 2002
Jul 06, 2008 09:38 |  #10
Try the same test but, instead of hand-holding the camera, put it on a sturdy tripod. You will probably see the sharpness you expect.
You could have some flare or other abberations with cheap filters, but you'd see that with most lenses.
Skip Douglas
Bubble
Jul 06, 2008 13:09 |  #11
Wilt wrote in post #5858489 (external link)
:lol::lol::lol:
Canon 5D II, 7D | 16-35L II | 24-70L | 24-105L | 50L | 85L II |  iMac 27 | Redrock Micro DSLR Cinema Bundle | Elinchrom Ranger RX-AS Kit| Elinchrom Digital Style 1200RX/600RX | Turbo SC |
cujojpn
Jul 06, 2008 13:56 |  #12
I dont think "Shakey" hands were a factor since it was on a monopod? But I can gauarantee that the results will be similar with the Sunpak, I was just curious and tyring to confirm that cheaper filter glass will have results like this.
I would have the same results with UV filter over the 70-200. It just has that massive amount of gaussian blur. I dont think what was displayed was motion blur.
Kaleb W.
Canon EOS 40D:
Sigma 10-20
Paul ­ Tinworth
Jul 06, 2008 14:24 |  #13
Even a monopod wouldn't ensure total stability (without IS) with that shutter speed at 200mm. I think perhaps someone is in denial! ;)
~ Paul
cujojpn
Jul 06, 2008 14:57 |  #14
lol i guess I am. So I am going to the same test at the same exposure We shall see what happends.
Kaleb W.
Canon EOS 40D:
Sigma 10-20
cujojpn
Jul 06, 2008 15:25 |  #15
Alright here is test #2.
This is with the CPL off, still remains the sharpness.
This is with the CPL on and taken at same shutter speed and exposure, I just raised the ISO so i could get some more light in the photo.
Kaleb W.
Canon EOS 40D:
Sigma 10-20
5,388 views & 0 likes for this thread, 14 members have posted to it.
1440 guests, 112 members online
