I've got a set of GNDs but seldom use them now TBH. I prefer to blend multiple exposures using HDR software, such as Photomatix. Its frowned upon by a lot of people, I know, who say you should get it right in camera, but it works for me. There are so many choices with the filters and I don't think having just one, will do the job. With sunrises/sets the exposure range will be considerable, and even a 3 stop grad may not be enough. In addition, you need to consider both soft and hard grads, depending on the horizon. If its level, then a hard grad is best, but if its irregular, then you really need the soft grads. This starts getting very expensive, and is a lot of extra kit to carry around. For many, well experienced in using these filters, its probably quite quick to decide which strength to use and to line up, but for me its not!
I use AEB and 2 stop variance. I shoot a test shot to check the exposure and adjust my bracket to ensure that at least one image has no burnt out areas. With sunsets however, you may need more than 3 exposures to get detail in the fg. Check the histogram for the shots and make sure that the full range has been captured by the bracket.
