Don1 wrote in post #5857992
Just yesterday I was shooting some planes in flight that were back-lit with a bright blue sky. Noticing that the planes were underexposed I tried using spot metering thinking that it would correct for the exposure. The results were not much different from using evalutive metering. So instead I adjusted the exposure compensation by 2/3 and that made a significant difference.
The 'spot', being somewhat large even at 3.5%, should really be considered to be a 'small area averaging' meter! If the object (e.g. airplane) does not fully fill the circle, the adjacent areas of sky will still be biasing the meter reading in the wrong direction.
Evaluative metering simply is an attempt to take a large number of photos in a wide variety of shooting situations, analyze the brightness of different zones in the photos, and 'program' the meter to behave in a certain manner. PHD (push here, dummy!) mode which might very closely simulate a spot mode in some cases. So it is not unexpected that its result might appear quite similar to use of the spot mode.
