Thread started 06 Jul 2008 (Sunday) 10:53
Starting Kit
powerguy
Jul 06, 2008 10:53 |  #1
Hi folks, I am brand new here and also to the digital slr scene. This looks like a great site with tons of information.
I am making the jump from a point and shoot to dslr. My photos will range from some indoor to mostly outdoor scenery,wildlife and some sports.
I am considering the following eqpt. and have all but pulled the trigger on ordering it. If anyone sees something that I could/should do different please let me know.
Camera: 40D
Lens one: Canon 17-85mm IS USM
Lens two: Canon 70-300mm IS USM
4 Gig card
Two UV filters
Backpack style bag
Looking at tripods as well
Thanks for the input
John
joedlh
Gallery: 52 photos
Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea.
Jul 06, 2008 11:05 |  #2
This looks like a good outfit for a first jump to a DSLR. I would recommend two 2gb cards instead of one 4. And buy the best quality. The flash card is a single failure point that will ruin your day.
As for the filters, if you're getting them to protect the front element, a hood is a better choice in my opinion. It actually contributes to the quality of the image by reducing glare instead of adding another piece of glass in front of your optics.
You might want to add a flash, for example the 430.
Joe
Gear: Kodak Instamatic, Polaroid Swinger. Oh you meant gear now. :rolleyes:
http://photo.joedlh.ne​t (external link)
Editing ok
Kevin034
Jul 06, 2008 11:12 |  #3
looks good, buy it.
Kevin
MKIII/5D/24-70/70-200/50
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Jul 06, 2008 13:06 |  #4
If you can afford a little more...
17-40 f/4L
70-200 f/4L
50 f/1.8
430EX
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
Amamba
Jul 06, 2008 16:17 |  #5
This is a good list.
I highly recommend Tamron 17-50/2.8 instead of Canon 18-55 IS because I believe it's better IQ and much faster. Unless you feel you want IS in 18-55 range.
I also recommend a CPL - I started using it recently on all outside shots when the weather is good and I believe it makes a lot of difference. If you get 2 Canon lenses you only need one filter, otherwise a step-up ring can be had very inexpensively from hvstar.com (and they have good prices on filters, too).
Canon 50/1.8 is cheap, very high IQ and fast. A great backup / low light / portrait lens for little money.
I'd hold off buying a flash until you're sure you need it.
I also agree that 2 smaller cards are better than 1 big one.
Finally, get a backup battery. Sterlingtek's are cheap and decent.
Good luck !
Ex-Canon shooter. Now Sony Nex.
Life Lessons: KISS. RTFM. Don't sweat the small stuff.
My Gear List (external link)
powerguy
Jul 06, 2008 17:05 as a reply to  @ Amamba's post |  #6
Anyone recomend the Tamron 17-50 f2.8 versus the 17-85 IS Canon I am looking at?
Amamba
Jul 06, 2008 17:22 |  #7
Oh, I didn't realize you were refering to the Canon 17-85mm IS USM. I thought you were talking about the new kit (17-85 mm IS).
I don't know how Canon 17-85mm IS USM compares to Tamron IQ wise.
RPCrowe
Joined Nov 2005
Jul 06, 2008 17:32 |  #8
ebann wrote in post #5859425 (external link)
17-40 f/4L
70-200 f/4L
50 f/1.8
430EX
I used almost this exact outfit for a while except that I had a 420EX flash and my 50mm f/1.8 was the older (and better) Mark-I.
It was a fair outfit but I really missed the range between 40 and 70mm. The 50mm didn't quite fill that range since using it meant a lens switch.
I bought a second camera which helped a little bit but, I was still not happy with the general outfit. Of course this is just my opinion and should not be construed to be applicable to all photographers:
The 17-40L; although a very nice lens just isn't long enough for me to use as a go-to mid range zoom. The f/4 aperture also limits my use as the go-to lens because it is a bit too slow.
The 70-200mm f/4L (non-IS) is a great lens but, for me, it is not a carry everywhere and use in most situations lens. I reserved the 70-200mm f/4L as a lens to either use in bright conditions or to use on a tripod or monopod.
I have gone through several lens and camera combinations until I settled on what is the best (but, most expensive) for my uses: 17-55mm f/2.8 IS and 70-200mm f/4L IS on 30D and 40D cameras.
I carry this duo everywhere and it serves me very well indeed. I no longer need to carry the 50mm f/1.8 lens because of the low light capability of the 17-55mm and I use the 70-200mm f/4L IS 3-4x more often than I was ever able to use the non-IS version.
I will agree that this outfit is probably a lot more expensive than most photographers can or want to spend.
I would suggest the 17-50mm Tamron f/2.8 and the 70-300mm f/4-5.6 IS lenses as a great pair. Although the 17-50mm doesn't have the range of the 17-85 IS lens; it does have a bit better image quality. Additionally, I have never missed the gap between my 17-55m and 70-200mm lenses.
xarqi
Jul 06, 2008 17:47 |  #9
Amamba wrote in post #5860699 (external link)
The which now? Are there two 17-85 IS lenses?
TaDa
...as cool as Perry
Jul 06, 2008 18:37 |  #10
I personally believe that a flash should be one of the main pieces of any starter kit. None of the lenses that you listed are fast enough for low light shooting. A good flash will help you change the quality of your images.
Name is Peter and here is my gear:
Canon 5D II, Canon 7D, Canon 40D
Glass - Zeiss 21 f/2.8 ZE, Canon 35 f/1.4L, Canon 40 f/2.8 STM, Canon 24-70 f/2.8
L, Canon 85 f/1.2L II, Canon 70-200 f/2.8L IS II, Canon 500 f/4L IS
Speedlite 580ex II, 430ex - Gitzo GT-3541XLS w/ Arca B1
Amamba
Jul 06, 2008 19:36 |  #11
xarqi wrote in post #5860831 (external link)
Me bad. 18-55 IS.. ehm ... was what I was thinking about.
jack ­ lumber
Jul 06, 2008 19:51 |  #12
TaDa wrote in post #5861087 (external link)
Welcome to the forum Powerguy. Another vote for adding a flash to your kit.
When I first started buiding up my gear, I had the philosophy that I would work with what I had, until I was missing too many shots because of insufficient equipment. It didn't take long before I bought a flash!
I don't see a card reader in your line up.??
There is a fine line between "hobby" and "obsession"
5D-20D-7D gripped- all canon-28MM 1.8 - 50MM 1.8 -17-40 L -100MM 2.8 macro -70-200MM L F4- 100-40MM L -1X4 teleconverter-Sigma 20-40MM 2.8:D 580 EX 11 flash- manfrotto tripods and monopods.
nordstern1
Jul 06, 2008 20:02 |  #13
hi John! welcome to the forum!:D
i would also like to suggest the tamron 17-50 instead of the 17-85 IS. if you could stretch your budget, the EF-S 17-55 IS is an awesome lens.
JOE
G10 | 5D | 40D | 17-55 2.8 IS | 16-35 2.8 L II | 24-70 2.8 L | 70-200 2.8 IS L | 85 1.2 L II | 430EX
manfrotto | tenba | crumpler | clik elite | tamrac | op/tech | blackrapid | sandisk | b+w | marumi | giottos | mac | buffalo
yogestee
Jul 06, 2008 20:12 |  #14
powerguy wrote in post #5860612 (external link)
Welcome to the cauldron John..
Yes.. The Tamron is a few stops faster than the Canon with brilliant image quality.. I'd go for speed over IS any day..
Jurgen
1,568 views & 0 likes for this thread, 11 members have posted to it.
Starting Kit
2712 guests, 161 members online
