Thread started 08 Jul 2008 (Tuesday) 07:12
AB800 - Dropped - Problem
whiskaz
Jul 08, 2008 07:12 |  #1
So one of my AB800s hit the floor over the weekend. Modeling light popped immediately, but a replacement bulb works fine. All else seemed OK, thought I'd skirted disaster. However, when I have my Skyport Receiver hooked to the strobe's sync port, I can fire one shot (via transceiver or the strobe's test button). After that, the Skyport turns off. I suppose it's caused by a short in the AB800?
The Skyport works fine on my other units. Shouldn't be a big deal to fix, but I think I've had the unit for longer then 2 years now (not sure). Then again, it was my fault so they probably wouldn't honor the warranty in that case anyway (though I've heard of them doing so).
Jeremy | Gear List | EyeDigress - A Photoblog (external link) | blinkphotography.net (external link)
"This aggression will not stand, man."
Double ­ Negative
*sniffles*
Jul 08, 2008 08:51 |  #2
You'd be surprised; give AB a call and see what they suggest.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
whiskaz
Jul 08, 2008 09:29 |  #3
Ha...yep... "Box it up, ship it back. We'll fix it." Wow.
Not sure which unit busted exactly, but if it's my oldest one, the warranty is up in September. Close!
Double ­ Negative
*sniffles*
Jul 08, 2008 09:35 |  #4
They're awesome like that. :)
568 views & 0 likes for this thread, 2 members have posted to it.
2678 guests, 163 members online
