Thread started 08 Jul 2008 (Tuesday) 12:47
Panning?
Brennan.M
Jul 08, 2008 12:47 |  #1
What is the best mode for panning, whats the difference and why?
www.qualityimagesupply​.com (external link)
Leica M3 | Mamiya 7 | Fuji X-Pro1
Double ­ Negative
*sniffles*
Jul 08, 2008 16:33 |  #2
Camera mode is irrelevant, mostly. But something manual would be better. M is really the best to avoid any variables (exposure changing due to moving scene). Take your reading, set the camera. Start tracking your subject, release shutter and follow through in tracking for a nice, smooth pan. If you have an IS lens and it has a mode switch, use mode 2.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 08, 2008 20:12 |  #3
Read these, & the links you find in them:
Advice needed for Rally shooting
1st attempt at horse panning
Brennan.M
Jul 08, 2008 22:58 |  #4
thanks those will help
Brennan.M
Jul 08, 2008 23:06 |  #5
and im gonna try to have my 55-250 IS in by the 17th
FlyingPhotog
Cream of the "Prop"
Jul 08, 2008 23:09 |  #6
Best tip here is Double Neg's "follow through" with your subject. Don't fall into the trap of "Stopping To Take The Shot..."
Good Luck
Jay
Brennan.M
Jul 08, 2008 23:19 |  #7
ok now what about speeds, its a road course (VIR). So I know I have to use Tv mode but what speeds for the shots? Probly be using the 55-250 IS most of the time the only other would be the 18-55 kit lens
Double ­ Negative
*sniffles*
Jul 09, 2008 05:55 |  #8
Depends, really. Anywhere from 1/125s down, I'd say.
SkipD
Joined Dec 2002
Jul 09, 2008 06:13 |  #9
TorqueJunkie wrote in post #5876756 (external link)
You do NOT have to use Tv mode.
Manual mode would be far better for racing. Why? It's because the color and reflectivity of the subjects change often, even though the lighting is the same. The meter in the camera is fooled by that, and every shot could be exposed a little differently.
Skip Douglas
Pete
Jul 09, 2008 06:17 |  #10
SkipD wrote in post #5877997 (external link)
This I totally agree with. Although of course it depends on the weather. If it's a part-cloudy day and the lighting conditions are changing on a frequent basis, then you're better off in TV mode. Otherwise trust in your light meter and manual mode.
Pete
UK SE Catch of the Day
PhotosGuy
Joined Feb 2004
Jul 09, 2008 09:28 |  #11
This shows how the subject can affect the exposure & why manual keeps me worry free:
Post #47
First set the f-stop & shutter speed you need. Then adjust the ISO.
Need an exposure crutch?
Brennan.M
Jul 09, 2008 09:45 |  #12
If anything else, Ill just wing it lol
1,283 views & 0 likes for this thread, 6 members have posted to it.
Panning?
2717 guests, 155 members online
