Thread started 08 Jul 2008 (Tuesday) 16:47
another try
mama2-8
Jul 08, 2008 16:47 |  #1
IMAGE: http://farm4.static.flickr.com/3039/2651127154_b3198c0bd8_b.jpg
Redman25
Jul 08, 2008 17:57 |  #2
It seems like you used your camera's on board flash, generally on board flash Isn't that great for portraits because it makes features seem flat and leaves harsh shadows. (were you looking for comments?)
Gear: Rebel Xt, 50mm 1.4, kit lens and a good old Pentax K1000 with 50mm.
mama2-8
Jul 08, 2008 18:03 as a reply to  @ Redman25's post |  #3
Yes, thanks for cc. That makes sense, right now I only have the camera flash nothing external yet. Can you make any suggestions on a flash for my 30d. I am glad you mentioned that I wondered why everything looked so soft. Also I have a lot of questions about the settings as in the temp setting, I am not sure when to change this and what it does. I think it stays on abou 5200 but do I need to change it with every shot. (still lost but slowly finding my way)
Redman25
Jul 08, 2008 18:39 as a reply to  @ mama2-8's post |  #4
Do you shoot RAW files? If you do you can leave the color temperature adjustment until after you take the picture, otherwise you'll have to change the temperature in camera which can be a pain (at least for me). AWB (auto white balance) gets it right most of the time, so until you become more proficient with other settings I'd recommend just leaving it on that. As for flashes, most people on the forum (as far as I know) wouldn't use a flash unless they could bounce it with an external flash unit. On board flash has it's uses too (such as for filling in shadows underneath the eyes on sunny days), but I would simply try and shoot without flash unless your just going to be shooting snapshots. Natural light can be beautiful. If your indoors, it may be tough to get enough light to shoot without a flash, but outdoors in a shady spot you should be able to get some nice pictures. (try and avoid direct bright sunlight for portraits because the lighting is very harsh) You could also try shooting by a window. All the assuming your looking to take portraits.
mama2-8
Jul 08, 2008 19:48 as a reply to  @ Redman25's post |  #5
So once i get an external flash then I could use my on board flash, otherwise I should not be using my flash for outdoor shots. Am I getting close?? So without my flash im going to have to turn up my iso pretty high? and slower shutter and lower f-stop to let more light in? Did I make any sense?
kimmylixx
Jul 08, 2008 19:52 as a reply to  @ mama2-8's post |  #6
get a 580exII and a bracket to get flash up off camera, if leaving on camera may want to get a stofen diffuser to soften the light .
arkansasbowhunter
Jul 08, 2008 20:05 |  #7
you can also use flash comp which will work to some extent.
what flash bracket do most of you guys use.
Canon Rebel XTI l Canon 70-200 f2.8 L IS USM l Sigma 17-70 2.8-4.5 l Canon 580 EX II Flash l Bogen Manfrotto 055XPROB Tripod l Manfrotto 488RC2 Ballhead
mama2-8
Jul 08, 2008 21:41 as a reply to  @ arkansasbowhunter's post |  #8
ok so if I get a flash how does it fire. Does it fire like my enternal flash when I shoot the pic?
Titus213
Jul 08, 2008 22:17 |  #9
The image is a great closeup, sharp, quite well exposed, with reasonable white balance. Cute child too. The light is flat - something that's tough to overcome using the built in flash as your main source of light. You can't point the built in flash anywhere but straight ahead. Back off a bit and use the flash for fill and you have another story. Closeup it works OK (not great, but OK).
Flash photography is another learning curve. An external flash is fired several ways, but just putting it on the hotshoe and bouncing the light off the ceiling and/or walls will improve the light quality considerably.
Dave
Perspiring photographer.
mama2-8
Jul 09, 2008 22:05 |  #10
Thanks Titus,
I appreciate your cc it makes me feel a little better. Ive been very discouraged and thought maybe it just wasn't for me, but like I tell my children we are not quiters and I am going to keep trying.
1,749 views & 0 likes for this thread, 5 members have posted to it.
another try
1794 guests, 164 members online
