I have a G2 that won't charge the onboard battery.
Here are the symptoms:
- Plugged into AC power, camera functions normally without a battery installed. Conclusion: AC adapter is functioning.
- Using batteries charged on an external charger, the camera functions normally. Conclusion: the batteries aren't the problem.
- Bottom line: on AC power, charge light on the camera DOES NOT illuminate under any condition, no matter what the charge condition of the internal battery
Here's what I've tried:
- swapped out batteries - no change
- changed AC wall outlets - no change
- checked firmware version. Upgrade not required.
- charged batteries on an external charger. All accept a charge.
Any thoughts? It seems to me that I have an internal charging system problem.
