Thread started 09 Jul 2008 (Wednesday) 03:39
Healing brush confusion
I ­ Simonius
Weather Sealed Photographer
Gallery: 19 photos
Location: On a Small Blue Planet with Small Blue People With Small Blue Eyes
Jul 09, 2008 03:39 |  #1
I have a great ugly long bit of grotty dust that I need to clone out but... when I try in CS3 phoitoshop nothing happens
I created a duplicate layer, selected healing brush ( also tried spot healing brush), drag it across the opffending bit of muck and it seesm to be working but when I lift the mouse it reverts to the image as it was - no change
what am I doing wrong?
thanks
Veni, Vidi, Snappi
Website  (external link) My Gear ---- (external link)
cdifoto
Don't get pissy with me
Jul 09, 2008 03:43 |  #2
Have you tried using the patch tool? if there's a sliver next to it that's identical (or damned close) in color, tone, etc. it usually works pretty well. I used it to remove sandals and wine glasses from a beach.
gkas
Joined Nov 2002
Jul 09, 2008 03:44 |  #3
I Simonius wrote in post #5877583 (external link)
thanks
Make sure that the SAMPLE pulldown is set to 'all layers'. Otherwise it will sample your current blank layer.
Gerry Kaslowski
gkas@socal.rr.com (external link)
Gerry's Pics http://MikeKazPhotogra​phy.com/Gerry/ (external link)
I ­ Simonius
Gallery: 19 photos
Jul 09, 2008 03:54 |  #4
cdifoto wrote in post #5877594 (external link)
no haven't got the hang of how that one works yet , but anyway it's a complicated bit of sky so I doubt it'd work here
gkas wrote in post #5877602 (external link)
tried that after your suggestion, no change:cry:
Veni, Vidi, Snappi
PamR
Jul 09, 2008 04:14 as a reply to  @ I Simonius's post |  #5
A couple of things to check:
Check the brush blend mode. Make sure it is set to "Normal".
If you use a graphics tablet, your healing brush might be set to "pen pressure". If so, it just takes an extra push to get the tool working. To check, right-click while using the healing brush, and check "Size" at the bottom of the dialog box.
Also, make sure you don't have any selections hidden (cmd/ctrl+h to hide all). If you do, cmd/ctrl+h to unhide, then deselect (cmd/ctrl+d)
Pam
http://www.pbase.com/p​am_r (external link)
I ­ Simonius
Gallery: 19 photos
Jul 09, 2008 05:06 |  #6
PamR wrote in post #5877667 (external link)
Hi - checked - yes -blend mode is set to normal
Either using a graphics tablet OR a mouse the same thing happens, it appears to be doing the job as I drag across the blemish but it reverts to how it was when I release the mouse or pen:confused:
Veni, Vidi, Snappi
René ­ Damkot
Jul 09, 2008 05:12 |  #7
Also check the blending mode of the duplicate layer.
Does 'regular' cloning work?
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
I ­ Simonius
Gallery: 19 photos
Jul 09, 2008 05:24 |  #8
René Damkot wrote in post #5877836 (external link)
yes all (two) layers are 'normal'
never tried regular cloning not got that far yet:eek: I only tend to PP rather than manipulate images, so for photos it's only removing dust spots really
Veni, Vidi, Snappi
cdifoto
Jul 09, 2008 05:33 |  #9
When was the last time you cleaned your sensor? Doesn't help these photos but sure would make your future a lot less spotty! :D
I ­ Simonius
Gallery: 19 photos
Jul 09, 2008 05:41 |  #10
cdifoto wrote in post #5877879 (external link)
clean it regulartily but it is never 100% sotless but then I go to the coast and only have to change lnses once with the wind and the cr*P in the air and hey presto -muck!
OK been experimenting more notice that if I use the spot healing tool about 5 times it gets it done so it seems that somewhere somethignis set to about 20% flow or fill but I have checked wherever I can and it is all set to 100%
In the process of trying different things the healing tool decided it would not flow but would only do a single spot- what's that about?
Veni, Vidi, Snappi
PamR
Jul 09, 2008 05:43 as a reply to  @ cdifoto's post |  #11
When all else fails, it's time to think about the nuclear option, resetting your preferences file:
http://www.creativepro​.com …hing-the-preferences-file (external link)
Pam
APG-Angus
Jul 09, 2008 07:12 |  #12
PamR wrote in post #5877899 (external link)
Cool, more like a Tactical Nuke, I 've used the multi warhead nuke to fix problems like this, uninstalling/reinstall​ing CS2.
This should be much faster so long as the prefs file acts the same way in CS2/CS3 as it does in PS7. Has anyone deleted this file in CS2, CS3?
Rich
5DMKII, 20D w/grip, EF17-40mm f/4L, EF 24-70mm f/2.8L, EF70-200mm f/2.8L IS, 2Ext, 580EX II, 580EX, Bogen/Manfrotto BO3021PB, Bogen/Manfrotto BO486RC2
https://photography-on-the.net/forum/showthre​ad.php?t=153724
PixelMagic
Jul 09, 2008 07:24 |  #13
Its easy to reset your Photoshop Preferences to their factory defaults.
Double-click the Photoshop icon to start it, the immediately press the CTRL+ALT+SHIFT keystroke combination and you will be presented with a dialog box; select "Yes" to confirm and you're good to go.
I reset my Preferences in CS3 regularly and I've never noticed any real downside other than having to redo my selections in Edit > Preferences > General.
APG-Angus wrote in post #5878193 (external link)
I ­ Simonius
Gallery: 19 photos
Jul 09, 2008 08:02 |  #14
FedkaTheConvict wrote in post #5878244 (external link)
so that's it is it?
reset the prefs?
Veni, Vidi, Snappi
cdifoto
Jul 09, 2008 08:04 |  #15
I Simonius wrote in post #5877896 (external link)
Ahhh gotcha. Sucks fo' sho'. :mad:
2,261 views & 0 likes for this thread, 8 members have posted to it.
1694 guests, 139 members online
