Thread started 09 Jul 2008 (Wednesday) 17:28
Sunpak 383 and hot shoe mount to S5 IS
dan_bgblue
Jul 09, 2008 17:28 |  #1
I have a question about trigger voltage and the Sunpak 383. I have read that it can be a concern when using old flashes with the new digital cameras when attached to the hot shoe.
I recently acquired a 383 and would like to check the trigger voltage. I think it needs to be under 7 or so DC volts. Correct?
Using a volt meter, I turned the flash unit on, let the indicator light for ready come on, and then checked the voltage across the 2 contact points of the shoe mount on the flash. I got a reading on my analog volt meter of 8.5. Should I be checking the trigger voltage this way or should I be checking it when the flash is firing?
Last question, is 8.5 volts at the flash a hazard to my S5 IS? If it is not a hazard, I think I am really gonna love this old workhorse flash.
Gear list: S5IS, 40D, Canon 17-55 f2.8 IS, Canon 70-200 f4 L IS, Sigma 150-500mm F5-6.3 DG OS HSM, Canon 50mm f1.8 mk1, Canon 85mm f1.8, Sigma 30mm f1.4 EX DC HSM, 430EXII, Kenko 1.4x TC, tripod
464 views & 0 likes for this thread.
2681 guests, 162 members online
