Thread started 10 Jul 2008 (Thursday) 09:08
Post Processing
dtufino
Jul 10, 2008 09:08 |  #1
How authentic are images when they are post processed?
with photoshop you can take an image that is SO-SO and make it oustanding, but... the question is how authentic is that image after editing, sure it looks good, but it's FAKE.....
Discuss....
-David T.
www.dtufinophoto.com (external link)
@dtufino_photo (external link)
Dermit
Joined Nov 2005
Jul 10, 2008 09:14 |  #2
All photos are fake. All photos are representations of the real thing. All images are post processed. Some are just done internally to the camera, some by people in programs like Photoshop... unless we are talking film, then the manipulation is done while developing/printing.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
dtufino
Jul 10, 2008 09:17 as a reply to  @ Dermit's post |  #3
True....
But what i meant is altering an image taken to make it looks GREAT often more takes away from the image! Don't u think.
I'd say that 98% of my images are straight out of the camera.... (no sharpening, nothing) that's how i like my images..... but i'm not the best photographer either... all i do is add my water mark and resizing for internet posting....
-David T.
bacchanal
Jul 10, 2008 09:21 |  #4
All images to an extent have the potential to misrepresent reality. Reality occurs over time, and to capture a moment in time can potentially be to take reality out of context. Also, cameras don't necessarily capture reality as our eyes see it...does this make any photograph a manipulation of reality? Exposure tricks, filters, lighting and post processing take that a step further. Authenticity is relative and depends on the purpose of the image and the way in which it is presented.
cdifoto
Don't get pissy with me
Jul 10, 2008 09:25 |  #5
dtufino wrote in post #5885357 (external link)
But that's not how I like mine. And that's ok!
tdodd
Jul 10, 2008 09:32 |  #6
The fakery starts before you even release the shutter.....
- when you use an ultra wide angle or telephoto lens the camera does not capture what the eye sees;
- when you choose a shutter speed you are influencing the capture of time/motion, if there is any;
- when you choose an aperture you are influencing DOF;
- when you choose a film stock or white balance setting, or use correction filters, you are making choices that change the colour of the light;
- when you add light - flash, hotlights, or use reflectors then you're completely altering the apparent reality.
Then, even without any manual post processing, there are different results from different raw converters, and different results from different sensors and different manufacturers and different in-camera jpeg processors. They can't all be right.
Then there are technical limitations in terms of dynamic range, lens sharpness, focus accuracy and diffraction effects. Colour spaces put further constraints on reality, as do bit limits on colour depth. Monitors can be uncalibrated and unprofiled, as can printers.
So what is real and what is fake, when it comes to photography? Where do you draw the line and who is to say which is which? Does any photograph actually look that much like the original scene?
FWIW I like to try to create/retain a natural look to my photographs, without any fakery, but they sometimes need a little helping hand to make up for my own shortcomings or those of the equipment or available light.
binliner
Jul 10, 2008 09:33 |  #7
PP can make a good image better but it can't make a bad image great if the image is out of focus, blurry or badly composed photoshop isn't going to help ;)
Imo tweaking things is all part of the fun but (I should imagine) it's even more satisfying if the image is so good out of the camera you can't make it better!!
Justin
website (external link) | flickr (external link) | facebook (external link) | blog (external link)
5D II | 7D | G1-X | 17-40mm f4 | 50mm f1.4 | 70-200mm f4 | 300mm f4 | 1.4x II | Lee filters
dtufino
Jul 10, 2008 09:33 |  #8
bacchanal wrote in post #5885384 (external link)
Great Point.....
-David T.
dtufino
Jul 10, 2008 09:36 as a reply to  @ dtufino's post |  #9
i'm in no way saying that Post Processing is terrible, just starting a little convo....
i'd need a bigger unstanding on how color correction/levels/cont​rasts work before i can do that....
this is my first ever attempt @ HDR
-David T.
Dermit
Joined Nov 2005
Jul 10, 2008 09:37 |  #10
True....
But you must realize that the camera itself is doing manipulation and doing it in a general sense. It does it generally because every image can benefit differently from different enhancements.
Are you arguing that you should only accept a shot how you got it with your specific gear and settings and anything above and beyond is 'cheating'? Because that is rediculous. Do you have any idea all the software and hardware it take to take visual light and convert it to data for display on a monitor and then to a print? It's all software and hardware that has been designed to do the same types of things you can do in photoshop or the like. So what's the big deal if I just fine tune what the camera/computer is already doing automatically? Do you shoot in RAW or Jpg? Do you realize that when you view a RAW image in something like Lightroom or ACR that what you are seeing is not really the RAW data as captured because that data would almost be unrecognizable. What you see is some adjustments already made automatically just to get something you can reasonably see. If you shoot in jpg, well the camera captures in raw anyway and then decides and automatically converts it to jpg, throwing out data it does not think you need and making the very adjustments you are arguing against, but just automatically with no input from you, the supposed artist here.
Do you ever use a filter like polarizer, UV, ND, GND? If you do then how is this different that making software adjustments? You are altering the scene as the human eye sees it. Even if you don't think you use a filter, you do because with all the optics in the lenses there is alteration, as well as an IR filter over the sensor in the camera.
Photoshop, and the like, is simply an extension of the tools already in place and working to capture a digital image in the first place. This type of discussion has been hammered over many times. There are mainly two schools of thought here. One is photography should be a means to accurately represent a place/event/time and any photoshop work should only be applied to make the image more accurately represent what was actual seen to the best of the recollection of the photographer. The other school of thought is to manipulate to your hearts content to make it the best possible looking image for what you have in mind regardless of accuracy of the actual scene. My take is that if you take an image 'beyond' reality then as long as you never intentionally misrepresent that image then who cares? Photographers are artists. And as an artist you have an artistic license to create art that is pleasing to you and maybe a specific audience/client. So who really cares how much an image is manipulated as long as you are honest in what it represents.
Are you the type that would be against me cloning out a beer can in an otherwise perfect mountain lake landscape, but it would be perfectly fine if I had removed the real can from the scene before I shot it?
dtufino
Jul 10, 2008 09:43 as a reply to  @ Dermit's post |  #11
Dermit, no saying it's "cheating" at all.... :-)
This is just an Open conversation. Thoughts, opinions etc. i sometimes see fit to use photoshop to edit the levels and curves.
But i realized that RAW images look alot better than Jpeg. so i been shooting RAW as of late.
-David T.
airfrogusmc
Gallery: 179 photos
Jul 10, 2008 09:45 as a reply to  @ Dermit's post |  #12
"You don't take a photograph, you make it."
Ansel Adams
"Dodging and burning are steps to take care of mistakes God made in establishing tonal relationships."
Ansel Adams
"The negative is the equivalent of the composer's score, and the print the performance."
Ansel Adams
Dermit
Joined Nov 2005
Jul 10, 2008 09:51 |  #13
dtufino wrote in post #5885502 (external link)
I got ya and I think i know where you are coming from. But you will never be able to get very many people to agree on how much is too much or how much will start to take away from the image. i also know a lot of people who really restrain themselves from using 'too much' pp work at all just in the name of trying to keep it like they captured it. Which is rediculous since most cameras fall short in many places of capturing data such as sharpness, color, etc. I admit i often see people pp images to the point beyond where i would do it, but that is my opinion and some people like the extra pp. I also see a lot of people doing things to images because they can, and not because they should.
Colorblinded
Gallery: 18 photos
Jul 10, 2008 09:55 |  #14
It is in fact very difficult to make a so-so image outstanding in photoshop without it being noticeable to a skilled photographer. I've seen many attempts, there are usually some tells.
Photoshop though does allow the average joe an easier time to trying many traditional darkroom techniques, although there are some that still don't feel as natural as the real thing (dodging & burning in particular still don't feel right to me in the digital darkroom).
It's all about moderation though, artists like Jerry Uelsmann did some amazing manipulations in a traditional wet darkroom.
Many good photographs rely on the right post processing to make them work. You can't always control everything when you shoot, as best you try. I tend to shoot for a certain purpose. If I want to shoot a pano, an HDR, or a crop other than 3:2 I usually know before hand. I have habit though of shooting compositions that I'd like better in 4:5 or square without even thinking about it though, but I find I like those aspect ratios better than 3:2 most of the time. I just don't generally crop my images to those dimensions until it's time for print, I usually do everything but the crop before I upload the images online somewhere.
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
cdifoto
Jul 10, 2008 09:58 |  #15
The minute you use flash it all goes out the window too. That light wasn't there before you tripped the shutter and it won't be there after either. :D
3,273 views & 0 likes for this thread, 29 members have posted to it.
Post Processing
2723 guests, 147 members online
