Thread started 10 Jul 2008 (Thursday) 14:13
protective filters
drumebskater
Jul 10, 2008 14:13 |  #1
i am looking to shoot paintball, so i need a good protective filter, but i dont want it to be too expensive, any recommendations? i am about to purchase everything off of adorama, so it would help if you showed me something there
are there any filter kits that would help me?
they are for 58mm lenses
Originally posted by Karl C: Amateurs worry about equipment, pros worry about money, masters worry about light...
SuzyView
Jul 10, 2008 15:36 |  #2
What size?
Any of these are fine
http://www.amazon.com …ywords=hoya+cle​ar&x=0&y=0 (external link)
Not cheap, but good ones. When you clean the filters, though, wet the cloth, do not spray the fluid onto the camera.
SkipD
Joined Dec 2002
Jul 10, 2008 19:14 |  #3
drumebskater wrote in post #5887033 (external link)
i am looking to shoot paintball, so i need a good protective filter, but i dont want it to be too expensive.....
If you're looking to use the filter as a protection against direct impacts, you should realize that filters are MUCH weaker than the lens elements in most of our lenses and will probably be smashed into thousands of small shards if directly hit. I certainly would not want my lens covered with paint that has glass shards embedded in it. That would be extremely difficult to clean off the lens without risk of damaging the lens with the glass shards.
What's the solution? A polycarbonate (plastic) such as Lexan or Plexiglas which is suitably flat and polished would make a far superior impact-protection material than thin optical glass that was NEVER designed with impact in mind.
Cheap filters will likely have little or no anti-reflective coating on the surfaces and, because of that, are very likely to cause flare in your images if there are any bright light sources that can impinge on the filter.
Skip Douglas
967 views & 0 likes for this thread, 3 members have posted to it.
protective filters
1130 guests, 168 members online
