Thread started 12 Jul 2008 (Saturday) 22:14
Exposure/Lighting/
ForHisGlory
Jul 12, 2008 22:14 |  #1
when I am doing in camera metering, and have my S. light attached. How much of a stop/many stops do I calculate in for my flash? i have a 580EXII and shoot with the xti.
Claire ~ Canon Rebel XTi EOS 400D & Grip, Speedlite 580EX II, 28-135 mm, 85mm f1.8,
Sigma 150-500mm, Dynatran Ball Head Tripod. WWW.ClaireGuthrie.com (external link)
To look through lens and press the shutter,
Is to capture the spirit of the created;
That the Creator may be glorified.
psycorpse
Jul 12, 2008 22:18 |  #2
Whats up with the big font? If you have the speed light in ttl mode you really wouldn't have to do anything from my understanding. The ttl mode acts as a fill flash. I guess it would be + or - for your liking.
EF 50mm f/1.8 II
DDCSD
GIVIN' GOOD KARMA
Jul 12, 2008 22:28 |  #3
That is a pretty loaded question. It all depends on what you are trying to do. The in-camera meter has nothing to do with what the flash is going to do. The camera meters for the flash in ETTL based on the pre-flash emitted by the flash. It will not register in your camera's displayed meter, it does it all internally and automatically.
Now, what I tend to do if using the flash as my main light source is to put the camera in manual and set it about 2 stops below ambient. I then set my flash comp to +1 to +2 (when bouncing). This will eliminate any ghosting from matched camera/flash exposures.
If using the flash as fill, I set the camera to a proper exposure, and the flash usually between -1 and -3. I only use as fill if my SS will be sufficient to avoid any motion blur.
Different situations must be treated differently.
Here is an amazing resource on flash photography:
http://planetneil.com …h-photography-techniques/ (external link)
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
761 views & 0 likes for this thread, 3 members have posted to it.
Exposure/Lighting/
2775 guests, 172 members online
