Hi all! This dilemma has been bugging me for ages; is there a definitive best practice in the application order of denoise (neatimage) and (smart) sharpen?! Very interested to hear answers!
Thanks,
Steve
meady100 Junior Member 22 posts Joined Feb 2008 More info | Jul 13, 2008 14:21 | #1 Hi all! This dilemma has been bugging me for ages; is there a definitive best practice in the application order of denoise (neatimage) and (smart) sharpen?! Very interested to hear answers!
SilverHCIC Goldmember 1,460 posts Likes: 2 Joined Nov 2007 Location: Swimming, cycling or running ... somewhere in California More info | Jul 13, 2008 14:23 | #2 Permanent banEveryone's workflow is different, but I generally reduce noise early and sharpen late. "It's easy to find your bike in transition when you're the last one out of the ocean ... it's no fun being lost at sea
Pete I was "Prime Mover" many years back.... 38,631 posts Likes: 25 Joined Jul 2006 Location: Berkshire, UK More info | Jul 13, 2008 14:24 | #3 Conventional wisdom might say to sharpen first.
darkvibe Senior Member 295 posts Joined Apr 2006 Location: Rochester, NY More info | Jul 13, 2008 15:29 | #4 I remove noise first then sharpen as the very last step. I don't want to sharpen noise in the image. http://www.darkvibe.org/gallery/
gcogger Goldmember 2,554 posts Likes: 1 Joined Mar 2003 Location: Southampton, UK More info | Jul 13, 2008 16:03 | #5 Why not try it yourself? That's what I did, and I ended up with a slight preference for sharpening followed by Noiseware. It probably depends on how you're using the noise reduction and sharpening, which is why I suggest you try for yourself. In my case I apply only a little noise reduction, and have Noiseware do just enough sharpening not to soften the image. Graeme
Irreverent Senior Member 393 posts Joined Jul 2008 Location: Devon, UK More info | Jul 13, 2008 16:09 | #6 FWIW, my workflow goes like this:
ImRaptor Goldmember 1,448 posts Joined Mar 2008 Location: Humboldt, SK Canada More info | Jul 13, 2008 16:12 | #7 I tend to leave sharpening to the very last step. http://imraptor.deviantart.com/
Jul 17, 2008 16:36 | #8 Thanks for all the very enlightening replies, everyone
macrojunkie Cream of the Crop 6,709 posts Likes: 2 Joined Jul 2007 Location: Somerset - UK More info | Jul 17, 2008 17:10 | #9 me,lordv and dalantech all denoise 1st.i then use leveles if needed.contrast.shadows,highlights.then sharpen usm 100-1-0 then save jpeg.i only sharpen once. Uk prayingmantis forum - http://www.dragonscrest.co.uk/forums/index.php
Bobster Cream of the Crop More info | Jul 17, 2008 18:36 | #10 just sharpen at the end, don't bother with anti-noise filters.. Robert Whetton
Irreverent Senior Member 393 posts Joined Jul 2008 Location: Devon, UK More info | Jul 17, 2008 18:38 | #11 Why would you say that Bobster?
-Douglas- Beware of DOUG More info | Jul 17, 2008 22:37 | #12 Pete wrote in post #5903338 Conventional wisdom might say to sharpen first. but consider that you have up to three phases of sharpening (capture, creative, output). The best way of removing noise, however, is to use a mask. If you select the noisy part of the image (usually the background), you'll preserve the detail in the subject to a greater efficiency. I agree Edit My Images- OK"Brain Fart" = an essential bodily function.
Irreverent Senior Member 393 posts Joined Jul 2008 Location: Devon, UK More info | Jul 17, 2008 22:44 | #13 You could take that a step further by saying that noise is probably likely to be more dominant in the shadows and darker tones, so use of a luminance mask would confine your NR processing to those areas of the image.
Bobster Cream of the Crop More info | Jul 18, 2008 19:26 | #14 Irreverent wrote in post #5931680 Why would you say that Bobster? I'm always very suspicious of "always do this, never do that" advice, because it completely neglects to consider that each image requires its own tailored approach to processing. Why would you never remove noise from an image, and why would you only ever sharpen at the end? i expose to the right as much as possible, so i have little noise (even @ ISO1600) Robert Whetton
Shooting Goldmember 1,552 posts Likes: 3 Joined Jan 2008 More info | I sharpen first that may increase the noise, then I use noiseware to wipe it all away, leaving a smooth image.
| Latest registered member was a spammer, and banned as such! 2527 guests, 170 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
