Thread started 14 Jul 2008 (Monday) 12:01
1D users help me understand
davidfig
we over look the simplest things
Jul 14, 2008 12:01 |  #1
I have been perplexed by the fact that Canon chose to make the 1D series with two memory cards, but one CF and the other SD. What's with that? I would rather have it like the D3.
Does someone know why Canon chose to do this?
5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
Mr. ­ Clean
Jul 14, 2008 12:05 |  #2
More choices? Who knows. Personally I kinda liked it. The SD card was fast to download from card reader to PC and it was nice and small. More storage in camera with very little need for additional room.
Mike
some shots @ Zenfolio (external link)
picturecrazy
soft-hearted weenie-boy
Jul 14, 2008 12:17 |  #3
I'm not sure either. As far as I know, all the fastest cards are CF. I would also really like dual CF cards as it just seems to make sense. It's frustrating if you're fired off a few frames writing to both cards simultaneously, and you know your CF card is done writing but the buffer can't clear because it takes a lot longer to write the data to the SD card. It doesn't make sense to me.
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
basroil
Jul 14, 2008 12:59 |  #4
Why? Flexibility. SD cards used to be smaller than CF cards, but usually were usually faster, which was great for RAW+JPG. Send the JPG to the sd card, RAW to the flash card. Nowadays, SD is just as large, faster, and cheaper than CF, so you'll get more out of a 1d than a dual CF card D3. You can use old cards just fine, and you can get new SD cards for cheap (i got a 8gb extreme iii card for 40 bucks).
and picturecrazy, you're just dead wrong there. even the fastest CF cards can't break 7.5mb/s on a 1dmkii, yet an ultra II sd can go past 8.5mb/s. on a mkiii, the difference is even larger. when transferring on a computer, the difference is just as large but opposite, which is what you might have thought. on a 1dsmkiii (only UDMA capable canon camera), then CF cards may be faster, but only if they support UDMA use.
sbressler
Jul 14, 2008 13:16 |  #5
Many photographers like CF more than SD just because CF is larger and thus harder to lose. However, SD has caught up to CF in most other respects. I find myself using SD in my M3 more than CF these days...
FOR SALE/TRADE: Canon EF 28-70 f/2.8L | Looking for a 1D Mark III? Look here!
Gear: Canon EOS 1D Mark III | Canon EOS 400D (XTi) | 35mm f/1.4L | 28-70mm 2.8L | 70-200mm 2.8L | 580EX II
eigga
Jul 14, 2008 13:31 |  #6
At first I didnt like it.... but after covering many events where cards get replaced very often I like the fact they are different...one more thing to help me keep the cards sorted...sounds silly but it does help especially when you have to change out cards in and make notes in 10-20 seconds. JMO
-Matt
Website (external link)
davidfig
Jul 14, 2008 13:39 |  #7
Well for me the CF card offers a measure of safety compared to SD. The CF card works more like a disk drive and can move sectors if there is an error.
Worst of all the SD card is so small that I could easily loose it. As a wedding photog, its a frightening nightmare to loose it.
davidfig
Jul 14, 2008 13:40 |  #8
basroil wrote in post #5909334 (external link)
So if this is the case, why not have a slot for two SD cards?
sbressler
Jul 14, 2008 13:43 |  #9
davidfig wrote in post #5909582 (external link)
CF and SD card, afaik, function exactly the same and both use flash memory. Neither is more like a disk drive than the other.
This is one of the best arguments for CF.
davidfig wrote in post #5909590 (external link)
Obvious answer here: CF has been used since the beginning and there would be an outrageous uproar to switch entirely at this point. It takes time. Most pros have dozens of GBs in CF...
basroil
Jul 14, 2008 14:20 |  #10
sbressler wrote in post #5909606 (external link)
Look back at when the XSi came out, people were upset that their new entry level camera would have to mean buying new cards.
And yes, CF and SD are almost the same, except for size and bus type. Even the actual memory controller is the same for both. Nowadays, if you wanted to fit an SD in a CF box, you could (and there are SD to CF converters out there)
Double ­ Negative
*sniffles*
Jul 14, 2008 14:49 |  #11
Versatility - and perhaps that two CF slots wouldn't fit within the space Canon had available?
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
picturecrazy
Jul 14, 2008 14:51 |  #12
I was talking only from my own experience. And shooting with just an SD card is a heck of a lot slower than a single CF card. But then again, I'm using a 1Ds mark III.
-Lloyd
Pete
Jul 14, 2008 14:52 |  #13
Also serves as a double backup, if one card (or writer component fail) during a shoot, the camera can still write to the other card. For this purpose, the smaller SD card makes sense (otherwise the body would be a lot larger).
Pete
UK SE Catch of the Day
basroil
Jul 14, 2008 18:07 |  #14
picturecrazy wrote in post #5910047 (external link)
Like I said, except on the UDMA capable 1dsmkiii, all canon cameras (that have sd) will write to SD between 10 and 20% faster. Also, if you shoot RAW+JPG, the time to write/compress a JPG will add to the time, which is usually 10-20% slower than writing RAW files (check RG's CF/SD card guide).
SOT
I make up stuff about Cameras
Jul 14, 2008 21:05 |  #15
I hate it. I will say that again I HATE IT.
Either two of the same or just one...WTF is up with that.
http://img81.imageshac​k.us/img81/8646/captur​e1o.jpg (external link)
2,338 views & 0 likes for this thread, 9 members have posted to it.
1045 guests, 111 members online
