Thread started 14 Jul 2008 (Monday) 12:06
Carrying Camera Mounted?
1downfall
Jul 14, 2008 12:06 |  #1
hey all. I have been going out recently with my lovely new tripod. Do you all that have tripods, such as a bogen ect; carry your pod with the camera mounted or do you take it off each time you move to another location....say 50-100 yds. away? I feel secure....just like to know how you all feel.
Bill (external link)
Whitley
Jul 14, 2008 12:56 |  #2
Humm have the same question.
40D/BG-E2N 5D/BG-E44
10-22, 24-105 L, 50 1.4
28-135 IS, 70-300 f/4-5.6 IS
Sigma 70mm EX DG Macro
Bogen 3211/488RC2 , Fastpack 350
Dermit
Joined Nov 2005
Jul 14, 2008 12:58 |  #3
I have a quick release so usually carry it not mounted, but I will occassionally carry it mounted if I am going a real short distance... but, when i carry it mounted I always have the neck strap on... and it has saved me once. The quick release was not on right or something, but whatever the reason it did come off and the neck strap saved the gear.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
fxk
Location: The vast wilderness of the Mid-Atlantic states
Jul 14, 2008 13:05 |  #4
I've carried monopods with bodies or big lenses attached - I had the benefit of the Arca-Swiss type of mounting, with either the Acratec/Markins spring pin safety system or the RRS type of safety stops. I'd guess tripod should not be much different than a monopod - just be sure everything is buttoned up tight, and keep the "slide line" parallel to the ground.
The RRS lever clamps are quite nice in that you can give them a quick visual check - but be careful the lever on the clamp does not snag on clothing, a bush, etc - it is called Quick Release - not positive clamp.
The other thing is that you can use the camera/lens strap as a tertiary catch - wrap it around the tripod in such a way that if it should slip out, the strap will catch it before hitting the ground.
hommedars
Joined Jul 2003
Jul 14, 2008 13:05 |  #5
When working outdoors, I have it mounted all the time. Just throw it over my shoulder and keep on truckin'. Unless you don't trust the mount or head for some reason, I don't see a problem.
MattMoore
Jul 14, 2008 13:21 |  #6
I carry it mounted unless its a big/heavy lens on the body or if the the ballhead is mounted directly to the lens tripod ring (i.e. white Ls) - I know what I just said kinda redundant.
OR
If there a lot of foliage/debris/"negoti​ating" involved in getting to the next spot, I'll stick the body/lens back in the bag (I don't want branches raking across my camera/lens).
Its more of a question of where I'm heading, not so much if my equipment can hold it.
René ­ Damkot
Jul 14, 2008 13:35 |  #7
Same here, Arca style as well.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1downfall
Jul 14, 2008 14:01 as a reply to  @ René Damkot's post |  #8
hey thanks alot all!. I do trust my head and pod. More than likely, just for added security I'll just use the intended quick release if I have to walk greater distances. thanks again!
birdfromboat
Location: somewhere in Oregon trying to keep this laptop dry
Jul 14, 2008 19:23 |  #9
The 1/4-20 threads that go into the body of the camera are under a lot of stress, and every time you mount an adapter or a battery grip, it wears on them. they aren't very deep, so the wear and stress are acting on a small amount of metal. All that said, I don,t worry about it as long as I know everything is in order and the quick release is set right. If you want to worry about metal fatigue and breaking bolts, don't drive a car, especially around other cars. Ther is a lot more than your camera riding on the quality of lesser bolt/thread mechanisms than the camera mount set up. I throw the tripod over my shoulder and move, I set the thing up in a boat and slam through chop that makes my knees ache at the end of the day. I am more worried about the lens mount than the tripod camera interface. 25 years and no worries.
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Looking through a glass un-yun
yogestee
Jul 14, 2008 20:03 as a reply to  @ birdfromboat's post |  #10
If I'm moving to a realitively close location I leave my camera mounted.. If its further I dismount my camera..
Jurgen
440roadrunner
Jul 14, 2008 20:45 as a reply to  @ yogestee's post |  #11
You might want to read this, my latest project. Pay attention to the way the factory integral head was attached by the ridiculous 1/4" brass thread, somehow cast/ crimped into the swivel. I just about fainted when I got that thing apart
http://forum.manualfoc​us.org/viewtopic.php?i​d=11056 (external link)
My point is, that something that appears hell for stout--may not be
2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
Mamiya M645 1000S, 45mm 2.8, 80mm 1.9, 110mm 2.8 + 2x extender
SlowBlink
"I like dog butts"
Jul 14, 2008 21:00 |  #12
I carry my 40 with grip on my tripod regularly with no problems. I'll put on 10k walking with it set up with no worries. Then again I'm not using heavy glass either. If I was I'd get a better ballhead.
Rob
Anatidaephobia - The Fear That You are Being Watched by a Duck.
Persephone
Jul 14, 2008 22:36 |  #13
The only time i ever ran with my camera mounted was during Take Back the Night. I'd run to certain points and then set it up for a long exposure shots. Some shots came out really well, the movement blur really nice. That was with a P&S. If it was my 20D I would most certainly couldn't have done it, the march was long and I was already tired from all of the prior events.
Gear list
"Do you think it was my choice to wed a man I did not love? Live a life I did not choose? I was betrayed by the very gods that once saw me as their own. But no more." - Περσεφόνη (external link), God of War
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 15, 2008 10:52 |  #14
Me, too. If/when you get a quick release, buy three. You'll lose one & when you need the third, they will have stopped making them & the new one won't be compatible with the old one. ;)
1downfall
Jul 15, 2008 11:49 |  #15
PhotosGuy wrote in post #5915197 (external link)
wow...great timing on the advice!! I searched frantically yesterday for my plate...lo and behold it slipped under the couch...hmmmm...silly kids. I have not searched online for an extra plate yet. I will need to do so quickly.
2,208 views & 2 likes for this thread, 14 members have posted to it.
2689 guests, 143 members online
