I have the 2 flashes plus a set of skyports and a couple of umbrellas (one silver, one translucent). If I set up both lights at the same distance from my model and set them both to the same power level (1/2 power, manual) I'm assuming I still won't have the same light output because:
a. The 580 is more powerful than the 430.
b. More light is lost shooting through the translucent umbrella than shooting into the reflected umbrella.
It all has me wondering, short of using a flash meter, how do I set my flashes to be the same light output or dial in a 3:1 lighting ratio? Trial & error?
If my assumptions are correct, and I shoot the 580 (stronger) through the translucent umbrella (more loss) and shoot the 430 into the reflector umbrella (less loss) will I be lucky enough that the difference in losses will offset the flash unit output differences? Na, no way!
