Thread started 15 Jul 2008 (Tuesday) 19:25
Portable backdrop recommendations
tim
Light Bringer
Jul 15, 2008 19:25 |  #1
Are there reasonably priced portable backdrops available? I would want to be able to take photos of 2-4 people on a portable white seamless.
cdifoto
Don't get pissy with me
Jul 15, 2008 19:36 |  #2
I got a couple on eBay pretty cheap & they aren't ghetto thin either. I think I paid $20?...and they're huge. Plenty big for 2-4 people. :D
My portable support is a relatively inexpensive set from Adorama. I'll have to look up the brand.
cdifoto
Jul 15, 2008 19:39 |  #3
Here's the support: http://www.adorama.com​/PABSS102124.html (external link) It has apparently gone up in price.
tim
Light Bringer
Jul 15, 2008 19:49 |  #4
Wow that thing is a monster! How long does it take you to set up? I was thinking a bit smaller.
cdifoto
Jul 15, 2008 19:52 |  #5
The center post comes in 3 sections and you can use two, effectively cutting the width in 2/3. It's easy and fast to set up. Just two standard light stands and a pole in the middle that feeds through a loop in the muslin. Folding up the muslin when you're done is another story. :lol:
The light stands are a lot lighter than typical stands though, which is nice. Sturdyness seems fine, although you won't want to be shaking it or anything. Basically apply the same common sense as you would to a stand with a light on it.
tim
Light Bringer
Jul 15, 2008 20:41 |  #6
Interesting, thanks. Still seems pretty big and unweildy, which is to be expected from a background system. I wish I had the space for a studio (sigh).
cdifoto
Jul 15, 2008 20:43 |  #7
You and me both. It's not that bad actually. You set up your stands, stick the bar together, slide it through the muslin, set it atop the stand posts, then raise the posts up to where you want 'em. Dealing with the fabric is the part that sucks, and that's the same regardless of the support system.
Now that you've reminded me I actually own one of these, I'm going to start using it as my kit for off-camera wedding lighting. I don't have a case for my NRG stands, and these are lighter anyway.
tetrode
I am a walking repository of thoroughly useless information
Jul 15, 2008 22:38 |  #8
tim wrote in post #5917871 (external link)
How about the Interfit INT714 Giant Collapsible:
http://www.interfitpho​tographic.com …Masters%20backg​rounds.php (external link)
98" x 16'. Collapses into a 39" case.
$149 at Adorama.
Dave F.
darkvibe
Jul 15, 2008 22:38 |  #9
cdifoto wrote in post #5917929 (external link)
I have interfit light stands. I was surprised how nice they were for the money. I would think their background stand is also nice.
http://www.darkvibe.or​g/gallery/ (external link)
Canon 30D w/ grip, 18-55mm kit lens, Canon 24-105mm f4L IS, Tamron AF 28-300mm f3.5-6.3 XR DI, Canon 50mm f1.8 II, Sigma APO 50-500mm F4-6.3 EX DG HSM, Sigma EF 500 DG Super, Slik Pro 400DX tripod, Slik Pro Pod 381 CF monopod.
bobbyz
Jul 16, 2008 10:10 |  #10
I would look at Photek People Popper. Not white seemless though.
I have Savage Port-A-Stand which I got for $129 from B&H. Came with 1 53" seemless white roll.
Fuji XT-1, 18-55mm
Double ­ Negative
*sniffles*
Jul 16, 2008 11:28 |  #11
Lastolite collapsible backgrounds.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
sdipirro
Jul 16, 2008 12:03 |  #12
Since he didn't say it had to be inexpensive, the Lastolite Hilite background might also be a possibility. It collapses into a very portable bag and provides that white seamless background for 2-4 people (4 might be tight). Works well in a tight space too.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
Double ­ Negative
*sniffles*
Jul 16, 2008 12:40 |  #13
^ Actually, I wasn't even referring to the HiLite and bottlecaps, but that's another option - albeit a somewhat pricey one. They also make black velvet, dyed and other collapsible type backgrounds, though they're somewhat limited in size. That is, they're not meant to be a seamless replacement, but rather a quick backdrop.
tetrode
Jul 16, 2008 13:23 |  #14
sdipirro wrote in post #5921993 (external link)
He also didn't say whether the groups were to be photographed full length. The (optional) train for the Lastolite apparently doesn't blend seamlessly with the Hilite itself. I think other collapsibles with integral trains might work better (i.e. require less PP) for full-length shots where the floor-wall seam is included in the photo.
Dave F.
tim
Light Bringer
Jul 17, 2008 02:10 |  #15
Thanks for the ideas everyone. The Lastolite stuff looks good. After looking at the options a portable white seamless is going to be big, unweildy, expensive, and most importantly a pain in the butt, so I think i'll just make do without one for now.
2,926 views & 0 likes for this thread, 9 members have posted to it.
2773 guests, 153 members online
