This may be a stupid question...but can i use the 5000K flourescent bulbs in my "hot light" set? I have a Smith Victor set of continuous lights.
christyjo2 Goldmember 2,275 posts Joined Oct 2006 Location: Arkansas More info | Jul 15, 2008 20:13 | #1 This may be a stupid question...but can i use the 5000K flourescent bulbs in my "hot light" set? I have a Smith Victor set of continuous lights. *Christy* "If at first you dont succeed...destroy all evidence that you tried." www.christyfullerphotography.info
SharonS Goldmember 1,231 posts Likes: 1 Joined Jul 2008 Location: Trinidad More info | Jul 16, 2008 11:59 | #2 I would like to know also Canon Eos 50D,Canon MP-E 65,Tamron 18-270mm , Canon 50mm 1.8, Canon EF 100mm 2.8 macro usm, 430 EXII, Kenko extension tubes set DG, 2 Vivitar HVS flashes,Tamron 2x SP AF Teleconverter.
Titus213 Cream of the Crop More info | Jul 16, 2008 12:14 | #3 I don't know if you can use the fluorescent bulbs. I checked the Smith Victor web site Dave
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 16, 2008 16:34 | #4 No reason why you wouldn't be able to screw in a CFL bulb in place of a tungsten lamp...the issue might be lack of intensity...you can get photofloods of 250W to 650W, and the highest CFL I have seen is equivalent to 100W. Color balance may be an issue. I have shot things for POTN illustration which were done with CFL and the setting of 2900k for the Lightroom balance gave very neutral results (validated against a Macbeth Color Checker). You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
BDDigitalImages Senior Member 557 posts Joined Nov 2007 More info | Jul 16, 2008 18:12 | #5 I use 55 watt fluorescents (250 watt equal) that I got on ebay in my continuous set that is almost the same as the smith-vector ones and have used them for over 2 years.The ones I use are 5000K daylight balanced. So I would say yes you should be able to use them.
SharonS Goldmember 1,231 posts Likes: 1 Joined Jul 2008 Location: Trinidad More info | Thank you all for your input,I will go ahead and get the fluorescent bulbs as recommended. Canon Eos 50D,Canon MP-E 65,Tamron 18-270mm , Canon 50mm 1.8, Canon EF 100mm 2.8 macro usm, 430 EXII, Kenko extension tubes set DG, 2 Vivitar HVS flashes,Tamron 2x SP AF Teleconverter.
| Latest registered member was a spammer, and banned as such! 2737 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
