Thread started 15 Jul 2008 (Tuesday) 22:00
40D Auto Exposure Bracketing
powerguy
Jul 15, 2008 22:00 |  #1
Brand new 40D owner here and I am going through the manual trying different settings. I can not get the camera to shoot the 3 shot exposures. I keep re-reading the manual to no avail. I am missing somehting easy I am sure. So if someone can give me a step by step I would appreciate it.
Thanks, John
Rafromak
Jul 15, 2008 22:38 |  #2
powerguy wrote in post #5918663 (external link)
Thanks, John
The best thing you can do is to buy a book such as this (keep in mind that this is not the only one, just the one I have): "Canon EOS 40D Guide To Digital SLR Photography" by David D. Bush.
The easiest way:
1. Press the Menu button, and look at the screen (notice the small icons or pictures on the top of the screen).
2. Rotate the Main Dial (by the shutter button) so that the second picture, from left to right, is selected.
3. Now, rotate the Quick Control Dial (next to the Menu screen), down/up to AEB, and then press the "Set" button (located right in the center of the Quick Control Dial)
4. Rotate the same Quick Control Dial to the desired f/stop you want. You will notice how the dots spread from zero (center). At the beginning you will see three dots next to each other. That means that the 3 exposures will be spread out through one f/stop. If you separate the dots further, that produces a wider range between exposures.
5. Press the Set button, and then exit by pressing the Menu button.
You can set the camera to take the three photos for you: Use the self timer, and the camera will automatically take three photos for you after the time delay.
Or, use the single shooting mode and take three photos by pressing the shutter button three times.
You must go back to the Menu and cancel bracketing (AEB) when not longer needed.
7D, 5DII
Hermeto
Jul 15, 2008 23:07 |  #3
To cut the long story short, set Drive mode to Continuous shooting and you’ll have 3 shots with one press on the shutter.
After that, re-read the shaded footnote on page 94 of the Instruction Manual.
powerguy
Jul 16, 2008 06:39 as a reply to  @ Hermeto's post |  #4
Thanks much for the help. It worked like a charm. The book will be ordered today.
Phebert
1 post
Joined Aug 2012
Aug 01, 2012 12:40 |  #5
I have the opposite problem - my AEB is set to bracketing - not sure how that happened - and for some reason I can't turn it off - any ideas?
WaltA
Gallery: 10 photos
Joined Feb 2006
Aug 01, 2012 13:39 |  #6
In the Custom Functions menu - turn AEB off.
Walt
400D, 5D, 7D and a bag of stuff
apersson850
Obviously it's a good thing
Gallery: 35 photos
Aug 02, 2012 05:03 as a reply to  @ WaltA's post |  #7
It's not in the Custom functions menu. It's in the shooting menu (red).
Anders
8,217 views & 0 likes for this thread, 6 members have posted to it.
2654 guests, 163 members online
