Thread started 16 Jul 2008 (Wednesday) 05:41
adobe bridge conversion
ccp900
Jul 16, 2008 05:41 |  #1
hi guys
simple question.
i shoot a 30d, i convert cr2 to dng via the converter. i tweak the pictures then use image processor to convert them to jpeg, 640x480.
Now, after the conversion, my resolultion is now at 300dpi. My jpeg quality is set to 12.
I want to get them to 72 dpi out of the conversion, meaning i wouldnt wann run through the jpegs again to convert them from 300 dpi to 72 dpi.
is there a way to do this within the image processor dialog box? if i bring down the quality to around 6 would that mean the dpi would be around 150ish?
id try it out but im still stuck at the office and i cant get this darn thing out of my head. im OCD that way hehe.
thanks!!
[Sony A7R Mark 3 | Sony A7S | Sony Zeiss 16-35m f/4.0 | Sony FE 28m f2 | Sony Zeiss 55m f1.8 | Sony FE 28-70m f/3.5-5.6 | Helios 44-2 | Helios 44-3 | Nikon 105m f/2.5 AIS | Contax Zeiss Planar 50m f1.7 | Contax Zeiss Planar 100m f2 | Voigtlander Nokton 40m f/1.4 | Canon 24-105m f/4.0L | Canon 85m f/1.8 | Sigma 30m f/1.4 | Canon 10-22m f/3.5-4.5 | Canon 100m f/2.8 Macro USM | Canon 580 EX Ver 1.0]
tim
Light Bringer
Jul 16, 2008 06:05 |  #2
DPI is irrelevant, its the number of pixels that's important, read my printing FAQ or the PPI FAQ for more details.
I don't know a way to set the images to 72ppi within your workflow, you'd probably need to do the convert to jpg with an action - which is dead simple to do.
Maybe google Dr Browns 1-2-3 processor, it might do it, it's like image processor on steroids.
rivan
Jul 16, 2008 10:27 |  #3
First, I'd also recommend you read the FAQs Tim mentioned.
Next, a few questions:
• For screen display, Tim is correct - dpi is totally irrelevant. Do you have another need for the DPI setting to be different?
• If so, which conversion step is setting the dpi to 300? CR2->DNG or the x->JPG step? If the former, you could easily build an action to apply during your 'tweaking' step.
Last comment: the quality setting in the image processor dialog pertains to compression level and has nothing to do with the dpi setting. The higher that number, the less-compressed the .jpg is, and the higher the quality, but the file is also larger. Lower numbers mean higher compression and (significantly) smaller file size but lowered fidelity to the original image.
René ­ Damkot
Jul 16, 2008 13:21 |  #4
ccp900 wrote in post #5920239 (external link)
This line is making no sense at all: The quality setting relates to jpg compression, and has nothing to do with dpi / ppi.
tim wrote in post #5920334 (external link)
DPI is irrelevant,
Quoted for truth
Yep. Image Processor doesn't, but 1-2-3-Process does.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
ccp900
Jul 16, 2008 21:06 |  #5
hi guys, hehehe.
i just wanted a 72 dpi so people cant get good prints off of it. And yep, i just found out that the quuality setting is for compression and to actually change the dpi i need to go into a picture and edit the workflow settings underneath.
thanks for chiming in guys.
tim
Light Bringer
Jul 16, 2008 21:23 |  #6
Hopefully you realise it's the number of pixels that matters, as well as the jpg compression ratio.
ccp900
Jul 16, 2008 22:07 |  #7
yep, thats why i crunched it down to 640 x 480 pixels and only 72 dpi. Im correct on this right?
tim
Light Bringer
Jul 16, 2008 22:15 |  #8
You're correct, but try this. Open the image in photoshop, choose images -> resize, turn off resample, and enter 1 in the ppi box. Close and save the file with a new filename. Now open the original image again, image -> resize, turn off resample, enter 10000 in the ppi box. Save it as another new filename. Compare the two files in any image viewer you like and describe the differences to me.
aram535
Jul 16, 2008 22:38 as a reply to  @ tim's post |  #9
Also JPEG compress of 12 is pretty meaningless for a 640x480 picture, for a single file.
If you're converting to JPEG for the compression and space, than 8-10 is a better range and will not effect the photo that much, but you save like 30-50% of the space.
If you're converting just because your Printer does accept TIFF files than find a new Printer.
Gear List * www.tranquilphotos.com (external link) * My Blog (external link)
ccp900
Jul 16, 2008 22:39 |  #10
ooohh. ok ill try that later when i get home. thanks tim.
im assuming the image would look the same because you didnt force the size to be set to something so if i move the ppi to 1 it bloats my size to some huge aount like 2,000,000 pixels by 3,000,000 pixels right? but the resolution wont change coz all the pixels are still accounted for.
so when i force the picture to just be 640 x 480 pixels and demanded that the dpi be 72 only it actually removed all the extra pixels....correct so far?
thanks tim!!
ccp900
Jul 16, 2008 22:41 |  #11
hahaha thanks aram. i actually tried converting using 10 quality versus 12 and yep you cant see the difference but the size difference is substantial. I might change my conversion now to just be around 10 since theyre only for web viewing anyways. i dont really print my own pics, if i need them printed i trot on down to the nearest kiosk.
tim
Light Bringer
Jul 16, 2008 23:02 |  #12
ccp900 wrote in post #5925887 (external link)
Nope, completely wrong. Remember we turned off resample, so the image will be exactly 640x480. I could tell you more but I suggest you try it yourself as I suggested above and find out for yourself, I know I learn better that way :)
ccp900
Jul 16, 2008 23:43 |  #13
yep, agreed nothing beats experience...ima go do that in a few hours when i get off work. Will chime in after thanks tim...oooh goddamn its fri tom and im on leave hehehe...ill catch up on monday!!
ccp900
Jul 20, 2008 20:53 |  #14
k, im back hehe.
tried the experiment and they looked the same, when i was changing the dpi though the size kept changing (size as in inches). so even though the picture was kept at 640 x 480, the size was changing like from 2 inches to .0002 inches.
tim
Light Bringer
Jul 20, 2008 21:07 |  #15
Correct. What difference did this make to how the image looked? None. So what difference does the ppi make? None. That was my point. Do you believe me now?
Note that this can make a difference for printing from some high end labs. My lab looks requires 250ppi and looks at the size in the exif to work out what size to print the image. This is a special, rare case.
2,216 views & 0 likes for this thread
Latest registered member is laylaholic
818 guests, 267 members online
