Thread started 16 Jul 2008 (Wednesday) 06:07
never used a flash
THE ­ TROOPER
Jul 16, 2008 06:07 |  #1
Hi, i have a 40D and would like to get a flash. Obviously i know about the 430 and 530 flash, and i was wondering if a 430 would be suitable for me.
I know nowt about it and don't even know what E-TTL means.
I hope you can advise.
Thanks all
Ian
5DII GRIPPED - 17-40L
http://www.dreamworldi​mages.co.uk/ (external link)
Dermit
Joined Nov 2005
Jul 16, 2008 08:23 |  #2
The best flash to get kind of depends on what you plan on doing with flash now and in the future. The 430 is an all around good flash and will suit most people's needs. It's plenty powerful enough and does most of what the 580 will do. If you want to use two or more flashes and have them wirelessly triggered by the Canon system then i don't think the 430 has the ability to be a master (trigger), only a slave. The 430 is less powerful than the 580, but still plenty of power for most needs. So you could get the 430 now and if you want wireless Canon ETTL with another flahs you could get the 580 later.
If you were to only shoot the flashes in manual mode it would be much cheaper to get some third-party brand flash and trigger them with some radio triggers like Pocket Wizards.
E-TTL is Evaluative Through The Lens. In a nutshell what this means is the flash will figure out automatically how much power to deliver to expose your shot properly. Of course as with all 'automatic' settings this system can also be fooled.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
mackidbrendan
Jul 16, 2008 09:12 |  #3
for manual, ie strobist stuff, i would get sunpack 283 or Nik*n SB-24's and if u really wanted u can even use a nik*n sb 24 on a canon hotshoe in manual mode.
Titus213
Jul 16, 2008 09:50 |  #4
As Dermit said, it depends on what you want to do with flash. Full auto mode shooting will cost you a bunch more than full manual by a factor of 3x or more. And more power generally means more money in either mode.
For an all around, useable flash to learn with I'd go with a 430EX. It offers full automatic (ETTL) mode and can be used in manual mode if desired. It's the lowest priced of the current lineup of Canon flashes.
Dave
Perspiring photographer.
THE ­ TROOPER
Jul 17, 2008 02:35 |  #5
Thank you for your replys.:) i am gonna get the 430.
Ian
cdifoto
Don't get pissy with me
Jul 17, 2008 03:00 |  #6
https://photography-on-the.net/forum/showthre​ad.php?t=138907
723 views & 0 likes for this thread, 5 members have posted to it.
never used a flash
2737 guests, 164 members online
